factory wiper arms?
Started by Lennard, February 12, 2017, 02:17:44 PM
Lennard
These wiper arms were on my '68 Charger when I bought it more than 10 years ago.  I wonder if they are factory original or aftermarket? They do have trico stamped into them but most '68s I've seen have a wiper arms that slide into the wiper blade.
cdr
mine are not like the ones pictured, mine are straight & slide into the blade.
ODZKing
Quote from: cdr on February 12, 2017, 11:56:13 PM
:iagree:
They should be the same as my 67 and look like this. Usually they were Anco in those years.
PlainfieldCharger
Could the Trico blades have come on the Anco arms?
Lennard
So I can assume that mine are aftermarket wiper arms?
ODZKing
Parts book lists both so my guess is the factory used what ever they had on hand.
Lennard
Quote from: ODZKing on February 14, 2017, 10:17:01 AM
Is that the answer to my, or plainfield's question?
ODZKing
Quote from: Lennard on February 14, 2017, 04:07:08 PM
Is that the answer to my, or plain field's question?
Sorry, that was confusing. I was referring to blades. Both were used.
However the arms are as stated earlier. All I have ever seen on 67s were Anco. While I believe that to be correct for 66, 67 and 68.
Also pictured below.
Lennard
Okay,  thanks for the replies guys.  :2thumbs:
