Spark Plug Heat Shields for 1969 440HP
Started by Charger69RTSE, February 03, 2017, 11:00:31 AM
Charger69RTSE
I am looking for information and pictures of what the correct spark plug heat shields should be on a 1969 440HP motor that was assembled on 01-04-69.   There appears to be (2) different ones available for the #6-#8 spark plugs as well as the #7 spark plug.   Thanks for any help.
birdsandbees
Only heat shield I'm aware of for the '69... #7. My engine was built Feb 28 69
But I've been wrong before and if you can prove it.. it means I have to buy more stuff !  :slap:
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
Charger69RTSE
Thanks for the reply but what I have read is that there are (2) heat shields available for #6-#8 spark plugs on a 1969 440, one that is for 1966 through mid year 1969 and one that is after mid year 69, the same for the heat shield for #7 spark plug,  I am just trying to figure out which ones would be correct on my motor with the assembly date of 01-04-1969.
birdsandbees
They're available... but I think they were only for '68 manifolds. Let me go find my sheets.
I do see that Greg is selling this though as a 67 to 69 item...
birdsandbees
I see what you are saying now.. they changed the shield profiles for later production dates. Yours is a Jan 4th engine.. fairly positive that is considered early.
Quote from: birdsandbees on February 03, 2017, 01:14:52 PM
not sure if this is useful info , or just going to confuse things , when I got my charger  ,   a bone stock  low miles  69  E series  440  imperial motor , complete with steel head gaskets , heads had never been off , was in there  ,  had the 69 hp b-body cast iron manifolds put on though  . had  a pair of those double heat shield thingys  one each side  ,  although I cant be 100% sure  , but seen to recall putting them back on every time ive swapped heads  :shruggy:   will have a check & look at some old pictures later
I never took many pictures , when I was doing the nut & bolt resto on mine  , these were before digital camera !   ,  heres a couple ive enlarged , you can see the shields ,   will take a few pictures  later if required  :scratchchin:  they may be wrong for a HP motor though & only for a C-body  :shruggy:
Challenger340
Ours is a 1969 Model Charger R/T SE, but built on Nov 22nd 1968.
If you don't get/find what you are looking for in a Pic? and I dunno if mine would be relevant or not here being a Nov '68 build , just say'in.... pm me and I'll go take some Photos
(ours is UN-restored, Un-rebuilt and still original #'s engine/shields, etc)
Only wimps wear Bowties !
Charger69RTSE
