What oils do I use
Started by Jduv10007, January 26, 2017, 11:11:18 AM
Jduv10007
Hello all.
I am leaking oil from my car. Charger owner lol. I have a 71 charger with a 383 that is sitting at my dads house and I am leaking oil. I haven't gone out to check which oil it is yet. But I am thinking it's coming from the trans. Anyways. I was wondering what oil everyone use for trans and engine so I can treat my charger right. Thanks for all your help.
Jason
Engine- brad penn
Trans: 727- lucas semi synthetic atf
             833- redline mtl or mt90
BSB67
certainly you don't think its the oils fault that it is leaking, right?
11.68 @ 120.2 mph
Jduv10007
Haha not at all. But I am going to change all the fluids looking for the leak and if the leak continues I will have more to add if it ever gets low. Don't want to add a bunch of different types of oil in the car at once.
Laowho
+1 on the Brad Penn. (Highest/best zinc levels and processing?)
Chargerguy74
Lucas Hot Rod & Classic Car engine oil.
Redline MT-90 in the 833s.
WANTED: NOS or excellent condition 72-74 4 speed shifter boot for bench or centre armrest car, part number 3467755. It's a rubber boot that looks like it's sewn up leather.
WANTED: My original 440 blocks. Serial # 2A188182 and 3A100002
Vegas_Nick
I run AMSOIL in everything I own and have no complaints. In the Charger, with the 80,000 mile engine that is in it now, I just dropped in Castrol High Mileage since I am only going to run it a short time then switching to the high zinc AMSOIL in it as well.
blakemon
My car engine seems to like Brad Penn oil.
