Gas pedal hard to push
Started by mx916, January 16, 2017, 01:01:20 PM
mx916
Guys, is it common for the gas pedal to be hard to push as compared to a newer car?  I have a '74 Charger with a 360.  I recall the pedal being hard on my '73 with a 318 that I had back in the '80's.  Is it just the way it is, or is there something I am missing that can be adjusted/changed/ or lubricated?  Thanks for any help.
Ryan.C
Wrong throttle return spring  :icon_smile_question:
There are few problems in life that cannot be solved with C-4.
XH29N0G
The only thing that should be holding it back is the throttle return spring.  I think you would need a monster spring to make it difficult.  See how the linkage works near the carburetor?  If you can manipulate the throttle at the carb, you shouldn't have much pressure on the foot pedal and you can also rule out the spring.   Also, you may also want to keep a spare throttle cable.  It is no fun when the little ball pops off the end and you are stuck somewhere with no easy way to fix it.
Or maybe it protects us.
TommyGun
If the carb has been changed make sure the throttle cable brackets are right and or lined up correctly.  My car had a mis match of parts and the linkage was not pulling straight back and was actually rubbing on the trans kickdown linkage causing a really hard pedal.
disconnect the cable at both ends and make sure it moves freely, if not, replace cable
Kern Dog
If the transmission kickdown linkage is incorrectly positioned, it can bind up and make the throttle hard to press.
JR
Disconnect the throttle return spring and check for binding/interference.
If it's still binding, check further.
If it moves freely, return spring is too strong, or mounted in the wrong spot.
I've also seen throttle linkages bind up on aftermarket air cleaners.
It should be easy to spot where it's interfering at.
