Emblem Paint Removal
Started by Davtona, November 19, 2016, 11:35:54 PM
Davtona
So I have an original RT emblem with very nice chrome but it needs repainted. I do not wish to re chrome the emblem but need to remove the paint from it in prep for a new paint job. What is the best method to use for this. I do not want something that might aggravate the aged chrome and cause problems with it if there is a bad or weak spot I'm not seeing. I'm leery of chemical strippers and how they would affect the chrome as in maybe a color change to the chrome. Also thought about lacquer thinner. Anybody been down this road before with some advice.  :scratchchin:
Lennard
I cleaned mine with soap and hot water,  then I taped off the areas that did not need paint, scuffed up the old paint with Scotch Brite,  degreased it and painted it Red with a spray can.
Looks like a new one. :Twocents:
Edit: The chrome and black paint were still flawless on my emblem.  Only the Red paint was faded.
Charger-Bodie
Quote from: Davtona on November 19, 2016, 11:35:54 PM
Soak in evaporust. If you leave it a couple days the paint will likely fall off. It will not do anything to the chrome.
If that don't work soak in lacquer thinner for a few hours.
Repaint red using a syringe ,carefully wipe any excess off of the edges. Then mask the edges and spray the black.
