Motor mounts.
Started by Windsor, November 17, 2016, 10:30:46 PM
cdr
Have you thought about a motor plate like a drag car ?
Windsor
In the process of building the "new" frame. Front crossmember (radiator/body mount) is 2x4x.120 steel cut and welded to to the correct angle to allow for correct body height. It will be welded to the frame then boxed in to cover up all the ugly cutting I had to do to get the metal straight. The location of the motor mounts will be right behind the OE crossmember.
Windsor
Quote from: cdr on November 17, 2016, 11:50:49 PM
I have. I actually use to run a front and mid plate when I first built it. Only issue with doing that with the setup I'm building, the front plate would block the steering shaft on the R&P.
After looking into the Chassis Engineering mounts, I'd have to use one of their tubular crossmembers. And would require me to build support arms/towers.  So, I decided to go with the Tin Man. I'll make a reinforcement plate that will weld to the frame for the tabs to weld to. I still have the locator bars from the plate setup, so I might transfer those over.
Windsor
These are the motor mounts. Props to summit for the discount and shipping speed. Shipped out yesterday, got them today. From measuring, it looks like I will be able to weld the frame tabs (longer straight edge) directly to my frame reinforcement plate. I'll see next week when I can get the frame back into the garage and test fit.
cdr
Windsor
Started mocking up the frame tabs. I'll transfer it to steel tomorrow. Monday, I'm gonna sand blast the front stubs and the frame where the motor mounts will be, that way I will have clean metal to weld to.
Windsor
Getting things mocked up while I save up for the back half of the frame. I don't like how little of the motor mount frame tabs meet with the side of the rails, so I'm going to mock some up out of plywood then get the steel shop to cut some out on their water jet. I had to put a significant notch on both of the forward tabs to clear the UCA, so I want more meat going onto the sides.
I am going to push the crossmember back and use the engine frame tabs that I have now to build tabs for a spool style trans mount.
