holley 1050 dominator
Started by tomfed, October 29, 2016, 08:30:51 AM
tomfed
any one have a holley 1050 they want to sell and looking for the 4500 series mopar performance intake for a 383-400 engine??
Challenger340
Depending upon your engine combination, there may be power gains running a 4500 flange adaptor DOWN to a 4150 std Holley Intake manifold, rather than 4500 Carb directly to 4500 Intake.
Sounds goofy I know,
but check around the internet for dyno results, the INDY 440-2A 4500 to 4150 as an example on the INDY manifold, again relative to combinations.
Only wimps wear Bowties !
Quote from: Challenger340 on October 29, 2016, 01:54:45 PM
Not goofy at all. I have seen the same thing. Basicly acts like a venturi. Measure for hood clearance.
Mefirst
If you want to go with a Dominator carb, get a two circuit one, stay away from the three circuit ones.
To get a Dominator to work right in a street ride it will need TLC. You will need to change out jets in the metering blocks (Emulsion Bleeds), change out the Transfer Slot and Idle Feed restrictors, Air Bleed jets.. Play around with engine timing depending on what kind of cam is in the engine. I dont know how much you worked on carbs, but to get a Dominator to work right is a challange and takes work, but most of all you need patience...
/Tom
tomfed
I only use this car at the strip only, any help would be great.
Mefirst
Tomfed* Read through these threads a couple of times. It takes you through all the steps of why and how.
http://motorsportsvillage.com/forum/viewtopic.php?f=6&t=9717
http://www.motorsportsvillage.com/forum/viewtopic.php?f=6&t=3742
http://www.motorsportsvillage.com/forum/viewtopic.php?f=6&t=3811
Sadly this forum is not active any more... and dont worry that the threads are almost 10 years old, the info is relevant and carbs still work the same they did some 10 years ago.... also check out and read the other threads in the forum. Digest the info you find there...
..AFTER you read through the threads I posted and understand the modifications you need to do to the carb, THEN you become a member of this forum http://racingfuelsystems.myfunforum.org/index.php Here youll get all the help you need with your carb tuning. Be prepared that the first thing the members in this forum will ask you before they will help is -Have you read through, understood and done/about to do the mods outlined in the threads I posted above!
Happy carb tuning!
/Tom
Cooter
I have two for sale. One is carb shop other is older.
