LCA bolts
Started by 1charger69, October 25, 2016, 05:38:01 PM
1charger69
Reassembling front suspension......been along time coming.....is there a trick for tightening?  The entire rod just spins in the bushing when it gets so tight?
BLK 68 R/T
Poly bushings huh? I had to hold it with a vice grip on the backside and tighten the nut.
1charger69
Bronzedodge
When I bought my polygraphite bushings years ago, they said to reuse the old bushing sleeves.  I never installed them.  Sounds like they shouldn't be that loose?
Mopar forever!
charger Downunder
Been there done that get rid off the polly and put in the original rubber bushes. With the original rubber bushes don't tighten them up fully with the car in the air or you will tear the bushes when you drop it down.
[/quote]
bill440rt
The car has to be on the ground with weight on the front end to do the final tightening on the LCA pivot nuts.  :Twocents:
birdsandbees
What I'm getting out of this is he's talking about the strut rod nuts...
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
bill440rt
Hmmm... that's not what the title of the thread is, though.
Put a socket/wrench on the other end of the strut rod while tightening and it won't spin.
Kern Dog
Quote from: charger Downunder on October 26, 2016, 03:51:24 PM
Strange that you OZ guys call them "bushes". I like bush but never thought to use pubes in my front suspension.
Lennard
Quote from: Kern Dog on October 26, 2016, 08:28:22 PM
Ignore Horn dog. He likes to glom onto other peoples topics just to post useless opinion.
