HP / TQ estimates
Started by Dreamcar, August 31, 2016, 07:00:16 AM
Dreamcar
In the proven engine combos section, Windsor posted his awesome 383>>438 build. I'm wondering what those HP/tq numbers would look like if this engine still had stock 906 heads. I'll likely have mine built in a year or so and that's looking like a great engine for my needs.
http://www.dodgecharger.com/forum/index.php/topic,125531.0.html
"And another thing, when I gun the motor, I want people to think the world is coming to an end." - Homer Simpson
1969 Charger, 383, Q5/V1W, A35, H51, N88,  numbers match (under restoration)
Very mild cam. 438hp, 440 ft lbs on stockers.
Dreamcar
That wouldn't be bad for a basic cruiser, but I like the numbers with the aluminum heads better.
BSB67
Quote from: Dreamcar on August 31, 2016, 07:00:16 AM
Can't say without knowing what is/will be done to the 906's
11.68 @ 120.2 mph
Dreamcar
Quote from: BSB67 on August 31, 2016, 06:40:58 PM
Assuming a stock rebuild. No porting etc
BSB67
Quote from: Dreamcar on August 31, 2016, 07:17:15 PM
Here is the problem, a quality rebuild will cost money.  Most people on a budget will not spend the $ necessary to get a good rebuild.  In turn the cheap rebuilds are junk, and cost a bunch of power.
Plan on $1000+ for your 906s to make them good, or spend a little more and get some Sidewinders or Stealths or something.  If neither of those are in you budget, save your money until they are.
11.68 @ 120.2 mph
