rebuild kit for "Federal" power steering pump
Started by Q5XX29, July 21, 2016, 07:27:20 PM
Q5XX29
I've seen several threads that discuss rebuilding a TRW or a Saginaw pump, and how to tell the three styles apart, but can somebody tell me about a source for ordering a rebuild kit for the Federal pump? My '68 Charger is leaking around the main housing o-ring. I would think it would be an easy fix, if I had the parts. Right?
dakota_gt on Instagram
Quote from: Q5XX29 on July 21, 2016, 07:27:20 PM
If that's all that's wrong with the pump you might try some miracle-in-a-bottle. The Lucas Power Steering Leak Stop has cured two reservoir leaks for me.
Q5XX29
Quote from: John_Kunkel on July 22, 2016, 02:24:48 PM
Thank you- I did already try that. This seal must just be too far gone...
WhiteOnGreen
Hi, I rebuild in my 68, same yours, reservoir leak. I purchase a o-ring OD 4 5/8, ID 4 3/8 W 1/8 with good result.
Look here https://www.sealingdevices.com/o-rings-size-chart O-ring 2-245
Mine is a TRW
Q5XX29
Quote from: WhiteOnGreen on July 23, 2016, 08:10:24 AM
Mine is a TRW
Thank you very much!
Nickrc3
Q5XX29, even if you need to rebuild, it's not a complicated process. Removing the pulley will require a specialized puller available via your local auto parts store. Most offer as a loaner with a credit card deposit.
The rebuilding kits are listed on E-bay and work well. The most challenging task on rebuilding the Federal pumps is aligning the rotor pin within indexed key of the body while keeping all the needle bearings in their positions.The kit I obtained had decent instructions, and with the FSM, everything went well.
crj1968
I bought a Federal pump from Summit for like $50.   :yesnod:
Just had to swap the pulley over. done !
https://www.summitracing.com/parts/aaz-20-6184/overview/
