Ashamed that I can't find the oil filter on '02 Cavalier
Started by chargermick, April 15, 2006, 06:13:05 PM
chargermick
Bought an '02 Cavalier for my daughters to drive. I'm doing some general maintenance, but I can't find the oil filter to save my soul. Anybody know anything about bow ties? lol
burnt69
well if it's like my 95 it's on the back of the engine half way up and horizontal and oil goes evrywhere when you take it off.
chargermick
Nope, not on back side either, I just looked. Is this crazy or what?
mikepmcs
mikepmcs
some more info i found on ask jeeves just now
Answer
It depends on what engine you have. If it is a 4 cylinder, look at the pass side front of engine underneath. You may have to remove a shield to get to it. If it is a 6 cyl look at the pass side on the rear of the engine under the p/s pump.
[improve answer]Answer
All Cavaliers are 4 cyl.
If it is a 2200(or 2.2L) The oil filter is on the back of the engine block near the bottom of the block. It is tough to see, just feel around for it. I remove the filter from the top because underneath is the axel and the flex pipe for the exhuast.
^^^ To add in it is on the passenger side of the engine block.
I remove the computer box just above the power steering pump filler and just move it out of the way. There are only 2 nuts. One on the shock tower and one on the firewall. You do not have to disconnect the wiring, it has enough slack to move it out of the way. Now you have enough room to get your arm in to reach the filter on the back of the block.
The location that is being given is correct if your 8th vin# is a "4", if it is not you have the newer style paper cartridge filter that is located on the driver side, front of the engine block mid way up.
chargermick
Thanks Mike, that helps a lot. I'll check it out first thing in the morning.
mikepmcs
Well did you find it, i gotta know now.  was it the paper filter type or what?? ???
chargermick
Yeah,I found it thanks to you! What a stupid place to put a filter. I'm willing to bet that the kids at Jiffy lube never replace that filter. Thanks again Mike. By the way, it was the standard metal screw on filter.
mikepmcs
I remember reading that the oil filter was an extra-cost option on the early smallblock Chevy motors.  Maybe that's why the filters are hard to find on modern Crapaliers.
HAZZARDJOHN
Quote from: chargermick on April 19, 2006, 05:24:18 PM
I worked at a Valvoline Instant Oil change, in high school. If they are the same as the 95-99 2.2 liter and you have an automatic, They are the biggest b**** of a filter made. Picture The middle of July and the car is running hot, Then they pull in and you have to stick your hand between the subframe rail and the exhaust flex pipe! :flame: I hated those, cause you would get either burn you arm from the exhaust or, the boiling hot oil that gets splashed everywhere, when you loosen the filter from the base. Who Designs these cars? what's their thought process? "Let's put the oil filter, which will get changed the most, in the hardest place to get to. Yeah that's a good idea!"
~HJ
My mechanic told me, "I couldn't fix your brakes, but don't worry I made your horn louder."
