right hand side mirror
Started by tiki, June 14, 2016, 04:50:18 PM
tiki
Did the 69 chargers originally have a side view mirror on the right and if so does anyone know the dimensions :cheers: for the drill holes because there is no right hand side mirror on mine
tiki
They are the original doors too! :cheers:
The right side mirror was optional  G31 was the code
Like others did I added mine to my Charger by eyeballing it...pretty much useless though...  ;)
tiki
Thanks ill check the code... :2thumbs:
tiki
Thanks for the link tan top i have to check the code and i don't  know if i really want one... :2thumbs:
Mytur Binsdirti
toocheaptosmoke
I glued a convex spot mirror on top of my passenger mirror, I agree it was about useless being flat...
Polygon
I just bought one off the Bay, and will put it on too. Drivers side is a non remote, so I bought one to match.
That other post was interesting. Do we use the factory location. or move it 3/8 for a better view? I figure a better view, since my car is a driver.
www.lostinspaceforum.com
If you like the old TV show, Lost In Space, check out my page
tiki
The door panel has a hole for the remote how did you use a non remote on the drivers side? :popcrn:
moparnation74
IMHO, I wouldn't waste the time or effort to add one....Not many buyers even considered that option back in the day
crj1968
Quote from: Mytur Binsdirti on June 14, 2016, 06:47:24 PM
Quote from: Just 6T9 CHGR on June 14, 2016, 05:21:18 PM
I'll second that as well.
Completely useless. More annoying than functional
Mytur Binsdirti
In fact, I'd say that because of the car's body lines and size of the mirror, the LH mirror is barely functional.
66FBCharger
Quote from: Mytur Binsdirti on June 15, 2016, 09:37:11 AM
That's true! I agree with that. The mirror(s) are one thing that drives me nuts. I drive the car a fair amount and I have been spoiled by modern day mirrors.
I saw reference to 1970 (only) Charger Rallye side view mirrors. Are these mirrors any better than the '68-'69 manual and remote mirrors offered?
'69 Charger R/T 440 4 speed T5, '70 Road Runner 440+6 4 speed, '73 'Cuda 340 4 speed, '66 Charger 383 Auto
SOLD!:'69 Charger R/T S.E. 440 4 speed 3.54 Dana rolling body
6bblgt
the passenger side mirror was rarely ordered as original equipment on '68-'70 b-bodies
a remote driver's side mirror was a popular OPTION on '68-'70 Chargers, but a manual mirror was STANDARD
IIRC the relief on the driver's side top pad for the remote "control" had a blank vinyl insert
the 1970 "sport mirrors" are smaller and the mirror head is mounted closer to the body - I'll ASSUME less usable .....
Quote from: 6bblgt on June 15, 2016, 11:56:40 AM
If they hadn't become mandatory by government edict, drivers side mirrors probably wouldn't have been ordered that often either.
BrianShaughnessy
I put them on.     Balances the car IMHO.
Quote from: BrianShaughnessy on June 15, 2016, 01:14:31 PM
I agree...."looks" good with both mirrors on..
Brock Lee
Quote from: tiki on June 15, 2016, 06:17:18 AM
Factory non-remote cars had a color keyed delete plug that filled the hole in the pad.
Quote from: tan top on June 14, 2016, 04:56:41 PM
there are a few good threads on the subject  , heres one of them
http://www.dodgecharger.com/forum/index.php/topic,111791.0.html
In this link you can see the difference in shape. While not big that pass side mirror works, you can catch the bind spot if adjusted just right.  :2thumbs:
Sublime/Sixpack
Having a mirror on the right side of these cars helps a lot when backing into very tight spaces. That's the main reason I installed them.
And like b5blue said, they can help with the right side blind spot if adjusted right.
Paul G
Quote from: Sublime/Sixpack on June 15, 2016, 06:16:00 PM
I have to second that. You cant really see much on the right side of the car in traffic, but it does help backing in to the garage.
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
TPR
True.
I find both of mine to be completely useless. I don't use them at all.
I check over my shoulder every time I change lanes. I'm used to it now and it's no big deal.
I wouldn't bother adding a RH side, unless you are particular about the symmetry.
TPR
1968 Dodge Charger R/T 440 - UU1 Light Blue Metallic
www.tr440.com
tiki
How does the after market mirror screw in is there a stud w/nut to be tightened and one screw from the outside?
68Charger4me
