Which Master Cylinder ?
Started by JMF, May 15, 2016, 06:37:24 AM
JMF
I need a new master cylinder for my 70 Roadrunner with power discs on the front, drums on the rear, please could someone tell me which one I need to order as the one on Year One which says it's for my car but doesn't look like the one on there currently , pics below, thanks
You have a drum booster and master. At the least you'd need a different MC. The booster may work depending on the type of calipers you have.
I have a Raybestos disc/drum master new in the box with lines exiting on the fender side. I'm not going to use it. I could dig it up if you want.
crj1968
Yeah you are in the same situation I was. Someone put discs on the front but left the drum/drum stuff everywhere else.
I just ordered a MC for 70 with discs.
Were your brakes working OK with what you have now?
JMF
Thanks , no the brake pedal is creeping down to the floor occasionally
oldcarnut
I'm having to replace the master cylinder for the 3rd time on my 70 RR.  Ordered a brand new one from advance and it has the ports on the fender side instead of engine.  The A1 cardone remans are leaking after sitting in the car unused for 6 months or longer for some reason.  Where else has anybody bought a new or reman without getting the leak issues.  I can get them replaced at Advance no questions but it a pain to keep exchanging out the car and worse the fluid is eating up the paint.
