How rare
Started by billssuperbird, May 11, 2016, 07:18:38 AM
billssuperbird
1979 dodge Magnum GT 360 with a factory sunroof $800.00 obo needs lots of work.
GreenMachine
I just bought one late last year for $400. It was a 1979 Magnum GT 360 factory 2 barrel with T tops, later converted to 4 barrel. It had been sitting for 10 years and didn't run. I think I got a real good deal. The factory 4 barrels are a bit more rare (you couldn't get a big block in 1979). The windshield wiper system is junk and should be swapped out for earlier set-up, I spent a couple hundred getting mine back to working condition. The lean burn system needs to be swapped as well. Good luck finding a fuel tank/sender for it too. There is a small following for the Magnum, but they aren't willing to pay high prices for one. They drive and handle good. I think for $800 needing work is about right, not a screaming deal. Here's a descent one that got bid up to 4K on Ebay (No sunroof or T tops):
http://www.ebay.com/itm/1979-Dodge-Magnum-/331841157672?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=snwUd84wtb8vVNPerVzBs%252FqvohE%253D&orig_cvip=true&rt=nc
Here's a pic of mine on the way home...
billssuperbird
This one is on  Pittsburgh craigslist under Mopar
GreenMachine
I would consider that a parts car. If bought as a project car, you'd be in it way more than it's worth.
http://pittsburgh.craigslist.org/cto/5535482128.html
Quote from: GreenMachine on May 11, 2016, 12:50:50 PM
:2thumbs:
 :popcrn:
 :popcrn:
billssuperbird
I have seen t tops but did not know they had a factory sun roof
Mytur Binsdirti
$50.00 would be too much.
polywideblock
sad to see that someone's pride and joy ended up like that  :rotz:
  and 71 GA4  383 magnum  SE
crj1968
birdsandbees
Worth $400, every day of the week at the local metal scrap yard.
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
69rtse4spd
Wounder if any of the sun roof stuff would fit the 69-70 Chargers. :shruggy:.
I'd make a stock car out of it.
GOTWING
walk away and count your blessings you didn't buy it. :pity:
ws23rt
If it was the ONLY one it would indeed be rare.  But being rare is not the only thing needed for value.
crj1968
Quote from: ws23rt on May 12, 2016, 02:09:56 PM
Would be a good topic... "Rare...yet worthless."
