Slight shuddering at 35-45 mph
Started by Brian L, May 05, 2016, 09:03:50 PM
Brian L
71 Charger, automatic. I'm getting a cycling vibration at 35-45 mph, especially at constant speed, not accelerating, just maintaining speed. It's not a constant vibration, but it cycles (vibrates for a second then stops, vibrates again, etc). I thought it might be a u-joint, but they look good and feel tight. The front u-joint actually looks new, still clean. I've only had the car for a couple of weeks, and I don't know the history of it (came from a dealer). It also makes a squeaking sound from the transmission. Trans fluid looks good.
I thought maybe it could be the stall converter. Any way to test it to make sure before I take it to a transmission shop? Any other ideas?
303 Mopar
Shift into neutral, this will help determine if it is the engine or the trans.  You should also check the front tires and suspension.
