Pushrod length
Started by C500, May 04, 2016, 08:58:07 PM
C500
Guys, Can anyone post up the length of the pushrods for a '69 440 HP engine. Need to get some from Summit with a bunch of other things, but nothing listed for the car and heaps of length options available. 300lbs+ of spring pressure (thick walls needed) ... suggestions on part/brands welcome  :cheers:
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
9.315 should be stock, but if you have changed anything, you should measure before ordering.
C500
Quote from: c00nhunterjoe on May 04, 2016, 09:28:45 PM
Ok, thanks... no block decking or head milling going on, but will measure to make sure  :2thumbs:
