Can you name these parts for me,please?
Started by cavemanno1, April 13, 2016, 10:06:30 AM
cavemanno1
Hi guys!
I went through all of my boxes,22 of them,and found some parts i have no idea what they are!
Could you tell me what they are for?My friend had to use every available space when packed them and some didn't come with any paperwork.
The third picture is showing the firm feel k member and LCA stiffening kit but there are two rods i have no idea what's for.
The first and second pictures i have no clue either.
Thanks,
Peter
BLK 68 R/T
1st pic is the exhaust tip hangers.
2nd is the emergency brake cable guide that goes on the bottom of the floor pan.
3rd is the strut rods - they go from the large hole in the front outside of the k-member to the outer hole in the lower control arms.
cavemanno1
ht4spd307
picture #2 in bag (one out of bag) is seat belt anchor brackets
cavemanno1
Thanks,and that little clip in picture number two?
Quote from: cavemanno1 on April 13, 2016, 11:59:30 AM
speedo cable clip
chargd72
Looks like you have some lower control arm reinforcement plates in pic 3.
keepat
3rd picture in the zip lock bag looks like a K member reinforcement kit.
Pat
green69rt
deleted.  You already have the answers.
cavemanno1
cavemanno1
Also got some pictures of my 4 speed trans.These numbers don't match with anything i got!Was told the trans and read end are original to the car but how can you tell?Can anyone tell me what they mean?
Lennard
Those black rods are torsion bars. As far as I know rear axle housings aren't date coded. Just the ring gear inside has a date punched into it. The transmission has numbers on it that will tell you the dates but I'm not that knowledgeable.  I'm sure someone else here will tell you.
gers1968rt
Looks like the last 8 digits of the vin  8B355645
I used to own a mopar because it was different, but now I know better.
