Pro Touring
Started by Classic69, April 11, 2016, 08:53:52 AM
Classic69
I and wanting to build my 69 Charger for extreme handling. I want to you what should be the first Aftermarket Parts to get it to handle better, and to get rid of Body roll.
HPP
Call Hotchkis, order everything in their catalog for a Charger, install, enjoy. Oh, don't forget some better wheels and tires to take advantage for the additional grip generated.
myk
Don't forget the brakes!
Lennard
Start with stiffening the unibody before you start adding a bunch of stiffer springs/shocks/swaybars.  Add factory-style torque box plating, subframe connectors, a lower rad support reinforcement, and shock tower-to-firewall braces.
(This does not mean, "put in the largest & heaviest set of subframe connectors you've ever heard of, and ignore the rest of the suggestions.")
Classic69
Thanks you I really appreciate it!
invincibleextremes
Well, come see me about the brakes and your wallet won't be as badly beat up, but as far as the suspension, look to sign your life away... sway bars, and torsion bars will set you back plenty... but anything more will clean you out completely
