440 valve cover gaskets
Started by blinkey, March 27, 2016, 08:14:33 PM
mopar0166
yes works great ,and worse case if you get a leak it really is that big of grind to take it off and try again
BSB67
Quote from: PlainfieldCharger on March 30, 2016, 09:00:32 AM
Quote from: BSB67 on March 29, 2016, 06:02:06 PM
Interesting.  I've never used a sealant of any type on valve covers.
Here was something I found after I put my gaskets on...
This must be your reasoning... :2thumbs:
https://www.youtube.com/watch?v=eHEcf0itBuE
Not really.  There are a couple of places I might use it depending on the parts and materials of construction of the parts, gasket material.  Just never thought of using on valve covers, and never had a problem putting them on dry.
I think the guy in the video is a bit over the top, IMO.
11.68 @ 120.2 mph
mopar0166
I always just put on new gaskets if I got a leak after install or one crushed too much you shouldn't need extra adhesive
blinkey
  So tonite Im gonna try the Felpro hard black gaskets cause I already bought them, I dont like them, just sayin ,,,a feeling
crj1968
Quote from: blinkey on March 31, 2016, 04:55:07 PM
I've got the same feeling
Noticed a leak this morning from pass. side valve cover. So I tried to tighten it up a bit...and then it became a gusher.   :brickwall:
All my parts store had was the hard fel-pros as well. They don't fit very well in the cover so I had to trim them up....we'll see.   :rotz:
I need rubber gasket with a notch in it that you put on the head first.   :scratchchin:
