440 valve cover gaskets
Started by blinkey, March 27, 2016, 08:14:33 PM
blinkey
   Trying on my 69  440 to put the valve covers on 3 times and they still leak,,,,,any secrets out there? Im useing the rubber ones
303 Mopar
Every rubber gasket I have tried leaked.  Go with cork with the thin metal band in the middle.
Ive had good luck with the moroso blue's. Steel core rubber overmold.
Quote from: c00nhunterjoe on March 27, 2016, 08:54:49 PM
I bought the same ones and they look awesome! Won't know how well they work for a long time to come though but I'm optimistic.
crj1968
I finally got mine to stop leaking with cheapo fel-pro cork gaskets and a thin sheen of rtv
polywideblock
permatex ultra  copper rtv for all here   :Twocents:
  and 71 GA4  383 magnum  SE
Mopar Nut
Quote from: Dino on March 27, 2016, 09:06:59 PM
x3
blinkey
   Do you use the permatex on its own , or with a gasket
lukedukem
Quote from: polywideblock on March 28, 2016, 01:09:28 AM
This stuff, with felpro cork gasket. no leaks
Luke
1969 Charger XP29F9B226768
1981 CJ7 I6 258ci
2016 F150, 5.0, FX4, CC
Quote from: blinkey on March 28, 2016, 08:32:24 AM
With a gasket.
birdsandbees
I installed my valve covers that last time in 1989. Cheapest cork gasket sold and I can't even remember if I put my old aviation gasket sealer on them. Still not leaking on car pull down.
Remember, do not over tighten the bolts!
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
polywideblock
  steel core rubber (blue ) , put copper  on both sides fit and do up finger tight, let set overnight and torque to spec
oestermarken
Quote from: Mopar Nut on March 28, 2016, 01:50:40 AM
x3
:iagree:
69 383 4bbl
White Hat Special
Light Bronze Metallic
PlainfieldCharger
I have these permatexed to the valve cover only. I can take it off and put it back on anytime. NO LEAKS
blinkey
Sounds good I found the permatex gold. Now what should I use to clean the oil with on the valve cover and head.,,,,,varsol?
PlainfieldCharger
I like to use Naptha. It is a strong cleaner that leaves no residue. You can get it at a Hardware store.  :Twocents:
BSB67
Interesting.  I've never used a sealant of any type on valve covers.
11.68 @ 120.2 mph
birdsandbees
Quote from: BSB67 on March 29, 2016, 06:02:06 PM
:2thumbs:
mopar0166
I have eddy heads, and alum cal custom valve covers.  I use cork and they seal great.  I also use a stud kit for the hardware.   no more leaks for me and I keep a stock of gaskets in the garage just in case.   reusable is never really reusuable they leak for a reason
miller time
Cork and black rtv with some brake clean on a rag and your good,  if you have stainless valve cover bolts, IMMEDIATELY put them in the trash!!
I put grade 8 bolts and stainless washers, that way if you over torque them by 2 lbs they won't snap off like stainless, its worth a $5 dollars and hassle, oh and some never seize, especially if you have a aluminum heads like me :D
mopar0166
PlainfieldCharger
Here was something I found after I put my gaskets on...
This must be your reasoning... :2thumbs:
https://www.youtube.com/watch?v=eHEcf0itBuE
mopar0166
no need for sealant for you crush the cork without killing it.  I replace them every spring and mid summer to give the aluminum valve covers a good deep cleaning.  haven't used sealant in years.  I know some like spray adhesive to keep the gasket in place but I moved on to studs the never move on me now.
blinkey
Thats a great idea. Are you using 6 studs, slide the gasket on , then place the valve cover on. That way gasket stays put
