440 Engine
Started by q8charger, March 09, 2016, 11:23:07 AM
q8charger
Hello ,
Any one know which year of my car engine is  440  or 440 Magnum ? Also i have AC
lukedukem
i got this from another website
http://www.forbbodiesonly.com/moparforum/archive/index.php/t-38493.html
Decoding Engine Stampings and Casting Numbers
Decoding the Stampings on Engine Pads:
A .020 oversize cylinder bores
Diamond Oversize tappets
E Cast Crankshaft
HP High Performance
L or LC Low compression
Maltese Cross .001" undersize main bearing journals
Maltese Cross & an X .010" undersized crankshaft rod journals
O.S. .005" oversize valve stems
P Premium Fuel
R Regular Fuel
RX or MX All main and rod journals .010" undersized
S Special engine
WT or TW Water Test
X .010" undersize crankshaft
Decoding the Year Codes for B & RB Engines:
(Stamped on engine pad)
A 1965
B 1966
C 1967
D 1968
E 1969
F 1970
G 1971
H 1972
J 1973
P 1960
R 1961
S 1962
T 1963
V 1964
4T 1974
5T 1975
6T 1976
7T 1977
8T 1978
Decoding B / RB Engine Block Casting Numbers:
Casting # Body B or RB Year Stock Cubes
1944929 Chrysler/Dodge/Plymouth B 58 350
1737629 Chrysler/Dodge/Plymouth B 61-64 361
2205712 Chrysler/Dodge/Plymouth B 58-66 361
1851729 Chrysler/Dodge/Plymouth B 59-64 383
2120329 Chrysler/Dodge/Plymouth B 59-64 383
2468130 Chrysler/Dodge/Plymouth B 59-71 383
3698630 Chrysler/Dodge/Plymouth B 73-78 400
3614230 Best B (400) Block
(Heavy Main Webs) B 71-72 400
1852029 High Performance & Truck RB 62 413
2120529 Chrysler/Dodge/Plymouth RB 59-65 413
2205697 Chrysler/Dodge/Plymouth RB 59-65 413
2205697 Chrysler/Dodge/Plymouth RB 64 426
2406730 Max Wedge RB 63-65 426
2532230 Max Wedge RB 64-66 426
2536430 Chrysler/Dodge/Plymouth RB 66-72 440
3698330 Chrysler/Dodge/Plymouth RB 73-78 440
4006530 Chrysler/Dodge/Plymouth B 76-78 400
4006630 Chrysler/Dodge/Plymouth RB 78 440
Decoding Big Block Cylinder Head Part Numbers:
(* = Most Popular)
Casting # Part # Year Engine Chamber
Type Intake
Dia. Exhaust
Dia.
1737637 2128533 58-59 361 Closed 1.94 1.60
1944705 2128533 58-59 361 Closed 1.94 1.60
1737637 2448752 60 361/383 Closed 1.94 1.60
2206924 2128589 61-62 361/383/413 Closed 2.08 1.60
2206324 2128589 61-62 361/383/413 Closed 2.08 1.60
2402286 2402358 62 413 Max Wedge Closed 2.08 1.88
2463209 2406754 63 426 Max Wedge Closed 2.08 1.88
2463200 2448752 63 361/383/413 Closed 2.08 1.60
2406518 2406736 64 426 Max Wedge Closed 2.08 1.88
2406516 2406732 64-67 361/383 Closed 2.08 1.60
2406158 2806019 67 440 Closed 2.08 1.60
*2780915 2800762 67 440 HP Closed 2.08 1.74
*2843906 2843904 68-70 383/440 Open 2.08 1.74
2951250 2843904 68 440 Open 2.08 1.74
3462346 3462344 71-72 383/400/440 Open 2.08 1.74
3462346 3671640 73 400/440 Open 2.08 1.74
3751213 3751218 73 400/440
(Motor Home) Open 2.08 1.74
3769902 3769910 74 400/440 Open 2.08 1.74
3769975 3769954 75 400/440 Open 2.08 1.74
4006452 3769954 76-78 400/440 Open 2.08 1.74
I believe this number in bold indicates your is a '78
Don't worry, smarter folks than me will chime in. if I'm wrong
Luke
1969 Charger XP29F9B226768
1981 CJ7 I6 258ci
2016 F150, 5.0, FX4, CC
polywideblock
hope this helps   look for this pad it will have all the info on it
  and 71 GA4  383 magnum  SE
If the top pad is stamped HP it's a Magnum (or Super Commando or TNT), if not it's a standard 440.
RallyeMike
Everything points to a 1977 low compression cast crank 440 .... at least as it came from the factory. The block color should be blue, so perhaps it has been rebuilt and other pistons, cam, etc. installed.
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
q8charger
It was bule  , so how much HP on it ?
Challenger340
Quote from: q8charger on March 09, 2016, 03:14:28 PM
I think the stock 1977 440's churned out about 230 HP ? On a really good day.
Only wimps wear Bowties !
BSB67
Quote from: Challenger340 on March 09, 2016, 05:56:48 PM
Now there is a bunch of reality that some people won't want to hear or won't believe.
11.68 @ 120.2 mph
RallyeMike
QuoteIt was bule  , so how much HP on it ?
Blue was the standard 440 color from 72 on.
The HP # is really not even something to worry about. It will move the car along ok and still have decent torque compared to small block, but due to the low compression pistons these came with, breathing fire isn't going to happen without changing that. It not an engine that was factory built for performance, but rather mostly to move luxury barges, trucks and motorhomes around.
1973 Charger "T/A"
Keep in mind that in '72 they changed the way horsepower is measured.
