Has anyone built there own wiring harness
Started by 73charger440, February 04, 2016, 11:39:10 PM
73charger440
So I've been going through just the ignition connector part of my wiring harness and I have 3 of them and they all are junk my question is I found the bulk head connectors  new and it looked  relatively easy just to run new wire there's only 8 and make a new one I'm not keeping the factory ignition, distributor or ballast so was going to remove that stuff anyways I have a 6Al MSD box and distributor. Is there any special type of wiring that should be used and I can tell the starter and charging wires are a heavier gage wire but not sure what size and didn't know if maybe I should use a little  heavier gage wiring or the stock size ? I don't care about originality just wanting it to function and look good.
I allways do.
ign system wires are enough in 14 gauge. Regulator/alt fields in 16. Senders in 16 or even 18
Charging wires... originals are 12, but 10 is better
frank1966
That's what it feels like with the ron francis kit! Iam doing all of my own connections and wiring, nothing like original, they supplied the fuze box, wires and connectors!
Rolling_Thunder
oldcarnut
I made my engine, dash, and headlight wiring harnesses.  I also went to the blade type fuses and fuse box. My dash is not stock and I upgraded all the harnesses to use relays and updated charging
