Fire ring ? ( copper wire into block )
Started by Nacho-RT74, January 26, 2016, 03:00:10 PM
Somebody told me locally when using copper headgaskets is better make a groove around the cilinder and install a copper wire in it ( groove must be half of the wire thickness ), what he called ANILLO DE FUEGO ( fire ring ) to keep safe the headgasket.
Of course he races and makes high compression rate engines.
Have you heard this before ?
here a pic of a grooved block
Yes, block O rings are common with solid copper gaskets, it compresses the soft copper to help prevent blowouts; personally I use steel piano wire instead of copper wire.
yes, exactly! has being told on solid copper gaskets, not multilayer... thanks!
Now another question..
What about when using a regular composite headgasket with the solid copper headgasket/shim?
Felpro sells this copper shim to compesate some deck or heads mill job but they don't say anything about these ring job!!!
