classic auto air
Started by frank1966, January 02, 2016, 09:35:21 AM
frank1966
Has anyone installed the perfect fit auto air? What does it look like in the engine bay? They told me the hoses will run through only one opening in the firewall, I have 3 openings for the AC/heat. thanks
  Same here. I hope to be installing in the next few months. I've a 70 Charger that had A/C long ago so have too many holes in all the wrong places. I'll be using panel adhesive to attach sheet steel from the inside to fill in. (Not worried about "stock" looks in any way.) Bill440RT has a topic on running new system to old vents that came out very clean.  :2thumbs:
oldcarnut
I recently installed it my non-ac 70 RR.  I post some pics when I get the chance
Hope this helps or let me know what else
fizz
I did during a full restoration (dash out) on a non ac 70 charger. Had to bend the tube from the firewall to the dryer to get a good mounting surface from for the dryer on the fender apron. Other than that, works perfect and install was easy.
oldcarnut
Mine was also a dash out and pretty easy.  I did have to send one pipe off the condenser back as it was made wrong.  Also i got a 45deg off the compressor for running better fit hose routing.  I had them send me the hoses uncrimped and longer so I could route them for my use.
fizz
Yes, order hoses uncrimped.
oldcarnut
Also your radiator hose won't look like mine running over the compressor.  I'm running opposite lower and upper than OEM.
