remote starter switch
Started by GN, November 10, 2015, 03:36:33 PM
GN
Do to my age, I need to wire in a remote starter switch. What I  need to know is where do I connect the wires on the starter relay,  what size wire do I use? Do I use a in line fuse?  What size or amp switch should I use? The ignition switch is not working and I am to old to lay down and replace it.
nascarxx29
Are you sure its the ignition switch .It could be neutral safety switch
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
GN
Pretty sure it is the ignition switch. I did replace the nss.
nascarxx29
Ifyou dont need the ign circuit for run .You just need battery power red positive to heavy brown wire from starter at relay to get cranking over
nascarxx29
10 12 gauge wire  should be ok  go from battery term on starter relay to heavy brown wire from starter at relay.basically same connection you use for a hand held held bump switch
nascarxx29
You can bypass neutral safety by grounding a wire and see what happens.  http://www.dodgecharger.com/forum/index.php/topic,18408.0.html
