is this a suregrip? *PIC ADDED
Started by r4daytona, November 04, 2015, 01:25:18 PM
r4daytona
the case is a 742 obviously, but can anyone tell me if this is a sure grip by the numbers below it?  I'm not that familiar with part numbers so I thought I'd ask.  This and several others are sitting at a location near me.  I haven't tried to turn one side of the axle to see if the other spins the opposite way.  This guy has a pile of axles and I spotted this so I took a picture and thought I's ask you guys.
cdr
6bblgt
if the rear axle is intact, there is no external indication that the axle has a sure-grip installed, short of turning one axle
the casting numbers on a center section don't know what gear resides inside or its status as a sure-grip or not.
On the 489 case the fill plug would be painted orange to denote a Sure-Grip no?
Not sure if its the same for the 742 ('68 & older) case....
skip68
Turn one axle, watch the other side, if it turns the same direction it's a sure grip.  If they turn opposite directions it's not.    :cheers:
cdr
is there a sure-grip tag on one of the carrier nuts?
Stegs
r4daytona
Sorry, thought they sent.  Here's two different ones.  Can't turn the hubs because this pile of axles has been sitting outside.
Definitely 742 castings but the pig is going to have to come out to know for sure if either has a limited slip in there.
r4daytona
there is a tag on one of the bolts but it's rusted and can't be read.
bakerhillpins
Quote from: Just 6T9 CHGR on November 04, 2015, 06:00:45 PM
I thought they had a white circle with an x in it, painted on it?
Quote from: r4daytona on November 06, 2015, 09:21:34 AM
As Ghoste states, I believe those tags are only for the ratio.
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
bakerhillpins
The few searches I did were lots of all sorts of info.. such as:
http://www.dodgecharger.com/forum/index.php?topic=9295.0
This supports the orange plug but after jan 1970
96' VFR750 (Sweet)
