69 brake question?
Started by lexxman, August 13, 2015, 09:16:19 PM
lexxman
Ok I'm running the new brake lines in my 69 charger.I have the divider block with the safety switch, should there be a proportionate value some where. I've seen picture where theres one for the back brakes. The previous own had taken it apart so I don't know what was there.
Mopar Nut
Quote from: lexxman on August 13, 2015, 09:16:19 PM
For the rear only if you are running disc brakes up front and then I would use an adj. proportionate valve on the rear line.
303 Mopar
You at need a proportion valve as the divider block only channels the brake fluid to front and back.  I replaced my block with an OEM proportion valve as it was the cheapest and easiest route.
lexxman
Picture I see have the proportionate value by the drivers feet just down from the divider. What good does it do there?
