show me your car lifts
Started by mally69, August 04, 2015, 01:26:54 PM
mally69
I wanna see what types of lifts you guys have in your garages. Postem up  :popcrn:
A12 Superbee
MaxJax, two post for low height ceilings. Goes up to 4'. As you can see, handles the B bodies well.
I rate it highly. Only drawback is the hoses can get in the way as they are too short but I believe newer versions have longer hoses now.
A12 Dodge Superbee Coupe 4 speed Car number 157 in the A12 Registry.
XBGT Ford Falcon sedan, same model as Max drives in The Roadwarrior, the yellow car he starts off in.
WANT: Triple black 68 or 70 Charger!
mally69
Awesome , it a time for me to buy one so I wanted to see what every one has.    Is yours bolted to the concrete??
69 OUR/TEA
mally , absolutely that MaxJax that A12 showed he has is bolted to the floor .
If you are doing research for a lift , there are basically three :
2 post style
4 post (drive on )
midrise scissor lift
It depends what you are intending to do with it and your vehicles .A 2 post is all around a good lift as you can take tires off/take the rear out/front suspension/etc but you must bolt it to the floor. A 4 post is great for storage as the car sits as it does normally(without the suspension hanging for indefinite periods of time ),easy on/off for quick things like an oil change,but if you want to take wheels off , you'd have to purchase the rolling jacks that are available for all models.Also , a 4 post can be moved around as it does not need to be bolted to the floor , and is usually 110 volts ,and if your ceiling is high enough , you can park another car underneath it .
A mid rise scissor lift is great for autobody/restorations ,taking wheels off,oil changes , and collapses down to less than 4'' when done , also is 110 volt . But you won't be able to take out the trans because it is directly under the middle of the car .
Also , what ceiling height do you have ? Because if it's less than 12' , you are limited to minimal 2 posts because most are overhead cables/hydraulic lines (clear floor) .
I had the opportunity to have all three as my garage was large enough to have them , a Bend Pak 9k lb 2 post(low ceiling lift, as my ceiling height is only 10') , a Prokar (Chinese) 4 post , and a Rotary Revolution mid rise (which for doing my Charger resto , was worth every penny) .
If I had to choose one , it would be a 4 post , and purchase the rolling jacks if you want to remove wheels .
Hope this helps.
Old Moparz
Mine are the Bend Pak HD-9's & have been great for the 10 years that I've used them.  :2thumbs:
I posted this a long time ago if you want to read up on a detailed review & installation.....
http://www.dodgecharger.com/forum/index.php?topic=22425.0
               Bob
              Going Nowhere In A Hurry
My shop ceiling is too low for a full-lift so my Challenger 9000 pound 2-post lift is along side my main shop.
Bob
69wannabe
Quote from: John_Kunkel on August 05, 2015, 12:08:32 PM
I have the same problem with my shop so I am looking to do the same thing beside my shop maybe next year! ;D
440
This is all I think I'll ever have.....
41husk
I have a portable bend pak one post marine battery operated.  It's pretty cool.  I also have a 4 post bend pak
1970 Plymouth Duster FM3
1974 Dodge Dart /6/904
oldcarnut
These are in my budget  :D
XS29L9Bxxxxxx
A couple of Backyard Buddy lifts, Made in the USA :coolgleamA:
Daytona R/T SE
Here's my Bend Pak mid rise scissor lift.
41husk
That looks like one hell of a nice lift there CHris
Daytona R/T SE
Quote from: 41husk on August 07, 2015, 11:18:03 AM
You bet it is , Allen ! ;)
69 OUR/TEA
The three I described above.....
mally69
Thanks for all this info guys I really appreciate it.  Looks like I'm going with a two post and I Def want that scissor lift as well. My garage is 40x60x12 ft high.
mally69
I also stumbled across this style lift. Let me know what your thoughts are on this one http://www.eagleequip.com/product/MobileMan.html
DixieRestoParts
Bought this from a friend of mine, who deals in them. 9K capacity, high quality, I think it retails for around $1500-1600. They have many different models and capacities available. If anyone is interested, PM me and I'll send you his number.
Dixie Restoration Parts
Ball Ground, Georgia
Phone: (770) 975-9898
Phone Hours: M-F 10am-6pm EST
mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price
69 OUR/TEA
 To go with a two post , clear floor , you need 12 1/2 feet ceiling . You need a baseplate two post lift  with even still 12 foot high ceiling, the one I have is the bend pak xpr-9 . Or like the one Dixie posted . Looks like the one Dixie posted is an atlas model which I have seen in person and looks real nice. If you want American made , the bay bridge of lifts are the Mohawks , but very costly. When I checked , it was like $6-7k for a two post 9k lb. depends what and how much you are going to use it.
69 OUR/TEA
Quote from: mally69 on August 10, 2015, 07:35:01 AM
I don't know about those , I'd rather have one that is bolted down , no matter how much they say those are sturdy . I have had my 04 ram quad cab 4x4 with a cap on my 2post bend pak , rock solid ! The lift did'nt even know it was picking it up !  :Twocents: before the price increased , I think I paid $2,476 delivered.
mally69
birdsandbees
This is what my 2 post did lifting my wife's sport trac on the trial lifts. Even though the floor is 6+ inches thick and 18 year old slab, too close to the expansion cuts. So I built a truss across the top that hugs the ceiling. I've had the 3/4 ton Crew cab Sierra on it since without issue.
Oh.. and a shot of my sons Fucus on the lift with his fluke plate they issued him. I thought he got it on purpose as a hint that he was next in line to inherit mine!  :yesnod:
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
mally69
Hey birds and bees  how high is ur ceiling and height of the beams on ur lift. Just curious
birdsandbees
Ceiling is about 10' 3".. those are 9 x 9 garage doors. I have to crouch a bit to work under an SUV / truck, but a car (without a wing on it) I can pretty much stand up properly.
The truss I welded up above it is 2" x 2" x .125 tube, within a 1/4" of the ceiling.
Wayne
