Air density altitude
Started by RECHRGD, July 30, 2015, 06:06:07 PM
RECHRGD
I have always been told that Spokane had "lousy air" for making power.  Today I ran across an old dyno sheet from years ago when I did a head/cam change with much help from Ron here.  In the fine print at the bottom of the read out was all the info I needed to do an on line calculation of the air density altitude at the time of the dyno run.  Although the dyno shop sits at about 2000 feet, when I put in the info into one of those online calculators it came up with 4931 air density altitude.  I think the best dyno I ever had was around 332 rwhp.  This one read 325 rwhp, but when I plugged everything into other calculators it came up with a possible 370 rwhp at sea level.  Never realized how much difference in power there is due to air density.  Makes me want to take a trip to a strip on the coast for some fun.......
13.53 @ 105.32
cdr
was your print out ,, corrected or not?  it will say on the print out.
RECHRGD
It doesn't say anything about it.  But, it has a number that I don't understand.....SAE: 1.04.
13.53 @ 105.32
RECHRGD
OK, my Google research tells me that the 1.04 figure does calculate a correction.  Now I'm sad......
13.53 @ 105.32
325 rwhp is nothing to be sad about.   ;)
cdr
what a dyno says is not what is important, you know what your car runs at the track, That is what tells HP    :Twocents:
BSB67
Quote from: RECHRGD on July 30, 2015, 07:44:50 PM
Usually dyno data is corrected.  Nobobdy want to see the actual hp.
The good news is that if you get to a lower altitude with a low DA, the car will still be faster.
11.68 @ 120.2 mph
cdr
Calculate HP From Weight and MPH
MPH    Weight
Your Horsepower computed from your vehicle weight of 3900 pounds and MPH of 105 is 360
this is from Wallace Racing,,, also based on 10% loss at the rear wheels, so i come up with about 330 rear wheel hp
cdr
like BSB67 said , better air, the more power you make.
myk
Quote from: Dino on July 30, 2015, 08:17:43 PM
I'd say that many of us would be glad to be officially putting that much power down.  I know I would...
Quote from: myk on July 30, 2015, 10:06:41 PM
Officially?  Hell, I'd be glad if I could lie about it.   :lol:
RECHRGD
Quote from: Dino on July 30, 2015, 10:08:34 PM
OK, you guys are making me happy again.  Thanks!!!
13.53 @ 105.32
myk
Shoot if I was putting down more than 250 I'd be sincerely shocked.  Is your block untouched, OP?
1974dodgecharger
like I said in another post are cars are not hp kings.  U have 4 bangers that have more hp than our old school iron.
330hp to wheels is nice for 440 tq was probably 425?
HPP
Try living in Colorado where out actual altitude is 6500 and our density altitude can be a high as 10-12k. I can't tell you have many 500hp big block claims  I've seen that are putting 275-325 to the wheels.
BSB67
Quote from: RECHRGD on July 30, 2015, 10:31:18 PM
You have to let go of the hp numbers.  It is a game.  Dynos are tuning tools.  The only time you can compare the hp numbers from 2 different motors is from the same dyno by the same operator.  If your dyno sheet said 280 hp would you be more disappointed?  If it said 375 hp, would you be happier?.  None of it makes a difference when you strap you butt in and drop the hammer, it is what it is.
I don't remember your build, or track conditions.  But for a car that is a driver with a stockish build and a non-techie, not-into-the-weeds motor guy, your doing better than 90% in your same category with a 105 mph.
Take joy in knowing that you are making more power (because your car is faster) than most Mopar hobbyists like you that have way more go fast parts than you.
11.68 @ 120.2 mph
RECHRGD
Quote from: BSB67 on August 01, 2015, 11:08:05 AM
Yes, the car does run strong.  I've always wondered what it would be capable of at sea level and that's what got me looking at the old dyno sheet.  Haven't been to the strip in years, but it was fun being competitive with cars that I thought would clean my clock.  Nothing too fancy about the build.  30 over 440, mopar aluminum 452 heads, comp cams extreme energy 5.25 lift cam, crane gold rockers, ebrock rpm intake, Holley 750 double pumper with ProForm main body, Hooker 1 7/8" competition headers, 2 1/2" exhaust run through ultra flow mufflers, 727 with trans go shift kit, 3.55 rear gears and 275/60/15 street radials.  The latest additions are a aluminum driveshaft and a Firecore RTR ignition.  It seems to be running better than ever.....
13.53 @ 105.32
1974dodgecharger
WELL SAID!!!!!  :2thumbs:
With density changes at tracks, our supergas car will vary from 145 to 156 mph.....
BSB67
If you have the track conditions (or the track/date and time) when you ran, you can calculate sea level et and mph pretty well.
11.68 @ 120.2 mph
Quote from: BSB67 on August 05, 2015, 05:48:40 PM
The car always runs 9.900.  ;)
