shifter tube removal?
Started by Crazy440, July 14, 2015, 01:48:14 PM
Crazy440
How do you remove the shift lever in the picture.
I used to have a handle on life....but it broke off.
The lever is welded to the shift tube that extends all the way up to the shifter handle. Only way to remove the lever is to remove the whole shift tube.
Crazy440
How would I go about doing that?
 What I'm trying to do is use the below pictured bearing instead of the plastic one.  $8 versus $80-$90.
Oops, on second look that IS the shift tube in your first pic. Bearing must slip on from the top.  :shruggy:
Crazy440
Come on.  There has to be someone on here, that can tell me how to remove the shifter tube, from the steering column.
Go to mymopar.com and download a FSM for your car.
