Edelbrock 1723 Fuel Pump
Started by 68blue, July 04, 2015, 09:00:01 PM
68blue
Replaced two in as many years, anybody else having this problem? Looking at a third. :shruggy:
myk
I'm having that same trouble with my electric pump; I never thought I'd hear about a mechanical one failing...
68blue
Replaced everything from the pump to the hard line primed car and fired it up. Drove it for 10 minutes then up a hill where I started losing power, returned when it went down hill then started losing power again died completely about a minute later now back home after a tow. Problem must be in the tank somewhere,but all the parts including the tanks are nearly new. :shruggy:
cdr
possible fuel pump push rod, or the cam worn out
68blue
Good thought, push rod looks clean with no burrs and the cam has very few miles on it. I run the zinc oil additive as well. It's like the pump loses it's prime and then can't get it back.
