Dome light connector question
Started by Staxbro, June 06, 2015, 03:41:29 PM
Staxbro
Need to get hold of this connector pin. It's from the yellow/pink dome light connector which runs from the main harness. Any ideas where I can get these from? Am remaking my harness from scratch and struggling to find any of these...
Thanks in advance for any help/tips.
nick
Staxbro
sorry, problem with pics- it's the single pins inside the two pin connector that connects to the dome lamp wiring coming down from the a pillar. (Single pink and twin yellow) this is on a 68 by the way...
comet_666
VegasCharger
Try these guys. I linked the page where the terminals you requested are on (2nd row down from the top).
http://www.repairconnector.com/categories/ALL-TERMINALS-AND-KITS/?sort=featured&page=3
Hope that helps.
:cheers:
Staxbro
Thanks everyone. They appear to be out of stock at both those stores, but at least I know what I'm looking for interns of manufacturer/brand etc.
Much appreciated.
ODZKing
If it is what I think you are referring to they are called Packard terminals. Series 56 I believe - I just went through this some months ago.
Here is a company for reference but actually I bough all mine on ebay.
http://terminalsupplyco.com/Store/Default.aspx?CATDRILL=DEL010&PCAT=54228#Categories
search "Packard Connectors" on EBay and you'll see them if this link doesn't work
http://www.ebay.com/sch/i.html?_odkw=Mopar+molex+style+connectors&_osacat=0&_from=R40&_trksid=p2045573.m570.l1311.R1.TR1.TRC0.A0.H0.XPackard+connectors.TRS0&_nkw=packard+connectors&_sacat=0
Staxbro
Hi mate- those Packard 56 connectors are the standard male/female connectors used for probably 98% of the wiring in Mopars, as well as being in general issue in GM and Ford at around the same time. The connectors I'm after are called Deutche Open Barrel Male and are basically the pin type connector. (Found that out from you guys, ta!  :cheers:
Hard to get hold of, but I'm sure I'll find some- no hurry as I have about 200+ Packard connections to make/solder/crimp/heatshrink first...
While I'm on the subject, if anyone knows where I can get hold of the button terminals at for the boot of the bulb holders in the dash wiring (l/r indicator telltale, hi beam
Warning/dash lighting (on orange circuit) that would be cool... Also the connector pins in the turn signal connector housing and the female connectors on the gauge connector ( Basically anything that is NOT a Packard 56.....)
ODZKing
Ahh, like on my speed control connector.
I'm sure you've found this but just in case.
http://www.amazon.com/Pico-Deutsch-Wedgelock-Connector-Terminals/dp/B001RPV7UY
The cases I had very little luck finding.  But Molex are close.  And I have PLENTY of those if you need them, LMK
