What's the safest route to run fuel line inside engine compartment?
Started by Skull-1, June 04, 2015, 06:51:51 PM
Skull-1
Just noticed that my 1969 Charger 318 has the fuel hose running within a few inches of the passenger side header.   Not liking this.  Any advice on the best was to run this so it stays clear or am I overthinking things?
http://www.dodgecharger.com/forum/index.php/topic,6231.0.html
1969 Dodge Charger "Ol' Yeller"
1991 Buick Regal Custom
1992 Buick Regal Custom
1995 Buick Regal Gran Sport
1996 Buick Regal SE (R.I.P.)
myk
Well the stock fuel line hugged the block, for the most part.  Are you running stock or a different version of fuel line?  In any case, the fuel line is going to be close to dangerous sources no matter what you do; it's an engine compartment after all...
Skull-1
Quote from: myk on June 04, 2015, 07:41:10 PM
This is the line from the tank to the pump with the filter in between.
Skull-1
Skull-1
Quote from: tan top on June 05, 2015, 06:29:29 PM
imo would not run rubber hose  , that far
Do I have to run a single, brand new line from the tank all the way forward or is there another option?
you can do  , think I might do that all in one piece , although you said you have a filter between tank & pump , so providing your fuel line is in good condition , could just run a new line , up the inside of the frame rail , like OEM & mount the filter /join  back side of the torsion bar cross member , see green arrow
Skull-1
