Broke down on the side of the road
Started by grdprx, May 20, 2015, 04:27:06 PM
grdprx
Went out for a cruise after work yesterday, super excited I finally got my floor fixed.  The Lokar throttle cable busted!   :brickwall:   :brickwall: :brickwall:  :brickwall:
Took all my savings for a Firm Feel steering box to pay the tow bill.....  Sucked hard core.
adauto
Never too many! 70 Chally R/T Convert-70 GTX-68-69-74 Charger-68 Dart GTS
http://a-dauto.com/  http://www.facebook.com/pages/A-D-Truck-and-Auto-Parts/67427352555?ref=hl
Charger-Bodie
For future reference. I've had this happen before. I always just turn the idle up and drive home slowly.
Aw CRAP!  :brickwall: Tell us more? How is it setup under the hood?  :scratchchin:
XH29N0G
It stinks and reminds me I need to buy a spare just in case.
Quote from: Charger-Bodie on May 20, 2015, 04:57:33 PM
I did the same thing when it happened to me.  It was an exciting ride though, because I couldn't get it going too fast and had stoplights and hills to deal with.  Don't know what the other people thought. :smilielol:
Or maybe it protects us.
RallyeMike
Awww..... shi..  .  .......Bummer!
You should be carrying baling wire and duct tape in the trunk  :slap:  ....and if you're really going to be a Boss, it should be camo-print duct tape!
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
grdprx
That'd be useful for the future. How do you turn up the idle?
I'm going to be buying a spare for the trunk.
BLK 68 R/T
At least it didn't happen when you were on this trip :) but still sucks either way. Hope you get it fixed soon.
grdprx
Quote from: BLK 68 R/T on May 20, 2015, 05:21:46 PM
That is exactly what I told my buddy!!!   Could have been a hell of a lot worse.
Quote from: b5blue on May 20, 2015, 04:58:38 PM
Nothing special, through the firewall and up to the edelbrock carb per the instructions.
I put the pedal down to the floor quite often, but who doesn't??
 awww noo , bummer !! not good  :icon_smile_blackeye:
:yesnod:   :iagree:   X2
Ouch, sounds like it wasn't a cheap tow either.
skip68
That does suck.   At least you didn't have to leave it sitting on the side of the road for hours alone.   Like others have said bump the idle up so it will do at least 10-15 mph and cruise home or to parts store.
grdprx
How do you bump up the idle, turn the carb adjusters?  I haven't messed with the carb much.
XH29N0G
There is a curb idle speed screw that can be turned in to speed up the idle and out to lower it.  The problem with using it to get back is you set it at something like 1800 rpm and that barely gets you moving.  When you stop, the engine wants to rev at that RPM too.  I have a manual transmission so I can put the clutch in to stop, but it is not fun to have it running like that.  When I came back, I was about 2 miles from home and needed to catch a plane so there was no time to do anything else.  Maybe the others set it to another speed and had it work better.
Kern Dog
You should always carry a few basic tools.
HANDM
bakerhillpins
Quote from: HANDM on May 20, 2015, 11:26:19 PM
AAA
Or join a car club and make some friends that have a truck and a trailer and are willing to tow someone!  I'd do it in a heartbeat for anyone I knew.
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
70-500-SE-EXPORT
That sucks. My lokar cable broke at the same spot luckily I was pulling out of my driveway when it happened. What a POS cable it was only a year old. I went and bought a OEM repro cable after that.
68 Charger original SS1 paint with matching # 383hp
grdprx
Quote from: 70-500-SE-EXPORT on May 21, 2015, 07:11:34 AM
Mine is a year and a half old, less than 800 miles I'd imagine.  I'm contacting Lokar about the 'limited lifetime warranty'...
RIDELIKEHELL
Brutal..I just bought a spare OEM at Mancini when I was in Detroit
AMD POSTER BOY
bakerhillpins
Quote from: grdprx on May 21, 2015, 07:30:39 AM
I would be shocked if they did anything more than gave you a new cable. And if it was me it would simply go into the recycle bin because I wouldn't ever use their stuff again. Heck with a 2nd report of the same failure on a new cable I will be avoiding them regardless.
96' VFR750 (Sweet)
myk
Like you said man, it could've been much worse.  Another good thing is that a lot of us have learned that the Lokar option may not be the best one.  I'm going to pick up a spare OEM cable as well.
BTW, how do you install the cable-just pass it through the firewall?
hemigeno
Years ago I had a 383/727 in a '68 Charger that had self-inflicted carburetor issues (played around with the Eddy's carb idle adjustment screws too much and broke off the tips of the screws in the seat  :brickwall: ).  The engine would only stay running if I kicked the idle adjustment up to about 2,100-2,200rpm or so.  That temporary solution worked fine while I was saving up for a new carb, until one day when I dropped it in gear to move the car around in my driveway.  Wham.  There went the sprag inside the auto transmission, which junked the case.  Had to save up for a 727 case/rebuild AND a carb.   :rotz:
Just sounding a note of caution, but I'd much rather chance it than be stranded on the road.  Glad you made it home OK grdprx - it could indeed have been much worse!
PlainfieldCharger
 :eek2: Breaking down because of anything really sucks...I always carry a small box of simple tools extra ballast, voltage reg, duct tape, 1 gallon antifreeze, good thing its got a trunk... :scratchchin: When the cable failed, what did it look like? Was it a lack of lubrication? Lead stop pull off?
grdprx
Yes, the lead broke off, I haven't taken it apart yet, need a replacement.  The cable passes through the fire wall in the casing and a mounted bracket.
In hind sight, I was in shock that it busted.  I didn't realize I still has my tools in the trunk from the trip a few weeks back.   It is what it is, all I'm out is some money.
