68 Column/Auto -- Conversion to Console/Auto -- Easy, Right?
Started by Pedal2Metal, May 04, 2015, 03:39:46 PM
Pedal2Metal
I assume I can convert from column/auto to floor/console/auto without cutting the tunnel. All I need to do is attach the correct brackets to the tunnel for the console. And then I just change out the collar in the column, or should I change out the entire column for a more stock look?
Also, if I decide to go for a manual, can I use a modern toploader five speed without having to cut the tunnel, and then use a console to hide the fact that it's humpless/centered in the middle?
I'm looking to keep a stock look either way. Thx.
32 Oakland V8, 42 Hudson Pickup, 58 Messerschmitt KR200, 60 Caddy Eldorado Biarritz Vert, 65 Ford GT40 351/Webers (CAV), 69 Shelby GT500, 68 Charger 440 R/T, 71 Hemi Cuda Vert 4-Speed Tribute
Moparparts
If you are interested in  the original console automatic linkage PM or E-Mail me i have it available
Rolling_Thunder
no cutting on the floor to change to a floor shifted auto....
modern 5-speeds usually at minimum require a BFH to get to fit unless you purchase a direct fit kit ($$$) from a vendor.
Your console can be used to cover any signs of a non-humped floor.
I ran a TKO trans and the console covered a lot of things. it looked stock = the look i was going for as well
