fuel
Started by slyfox, April 26, 2015, 05:39:48 PM
slyfox
I own a 76 Cordoba, I've installed a Edelbrock intake, and a Edelbrock 600 cfm carb, I know it's a low compression engine, it's a 400, with duel exhaust with Hemi mufflers on it, I'm running 87 Octane, I heard that low compression engines run ok on regular, will it make a big difference if I use 91 octane in performance, and is it true that 91 octane as no ethanol in it, I know that 87 does, Thanks.... Sly
BSB67
Quote from: slyfox on April 26, 2015, 05:39:48 PM
....will it make a big difference if I use 91 octane in performance....
No.  None
11.68 @ 120.2 mph
