CSU Carb leak (Holley)
Started by chargd72, April 23, 2015, 08:52:19 AM
chargd72
I have a blow thru carb from CSU that is leaking fuel.  The leak is coming from the small hole (pictured below) by the accelerator pump.  I'm guessing it has something to do with the float levels but I'm not familiar with Holley carbs so I wanted to check before I dive into it.  Fuel pressure is at 7 psi.
chargd72
Talked to Kevin at CSU. There are small plugs that go in those holes. He's sending them over. Great dude to deal with.
