best carb for street use
Started by mustanghater, August 09, 2005, 10:25:59 AM
mustanghater
whats the best carb for street and sometimes track use?
New Muscle car forum
http://usav8.com/aamc/index.php
www.myspace.com/spencespeed
MoparYoungGun
It depends on the engine size as well as other factors. We need more info to go on.
mustanghater
MoparYoungGun
Possibly a 570cfm Street Avenger or just a regular 600cfm Holley.
Dr. V
I have a 670 avenger on the charger and chally.  It is perfect.
Holley has a 390 & 450 cfm 4 bbl which are awesome on small 6 s
mustanghater
are all carbs universal? I'm not an engine guy so I'm asking these Q&A's
MoparYoungGun
Quote from: mustanghater on August 09, 2005, 12:19:35 PM
Yes and no. There are basically two types of carbs, square bore and spread bore. A square bore carb cannot fit a spread bore intake and vice versa. But basically any sqaure bore carb can fit on a square bore intake. It might not be the right carb for the engine but it will phisically bolt on. I hope I have cleared up some of your questions. Good luck :cheers: !
It'd probably help if we knew your goals and a some more specifics about the engine and vehicle.
