steering column mounting plate bolts
Started by tiki, April 17, 2015, 04:43:07 PM
tiki
Does anyone know the correct size bolts for the steering column mounting plate bolts on a 69 charger r/t? :cheers:
kanadanmajava
Do you mean the ones that go through clamp 19-14-35? Mine's not R/T but it is a '69. I just removed the rearmost ones two hours ago. There weren't bolts but studs. The frontmost was a bolt with really weird nut.
Or do you mean the plate that connects the column into the firewall?
tiki
no 19-14-23 and 19-46-44 thanks for your help! :cheers:
tiki
Thank-you very much and the search is on
