Frame Rails
Started by xoman60, April 09, 2015, 05:06:23 AM
xoman60
Anyone know if someone sells frame rail bumpers? Something to protect them while lifting the car.
68pplcharger
I bought a floor jack with a rubber pad installed. If you have a nice floor jack most of them you can buy the insert with a rubber pad from the manufacture and in some case aftermarket.
Canadian1968
By the sounds of it you have the chassis clear coated ?? Roll up a rag and place it between the jack and frame , or a piece of 2x4 even should be fine . As mentioned a lot of new jacks have a rubber lift point which should be fine .
Mopar Nut
hemi-hampton
I use old wool rubbing pads. LEON.
polywideblock
a folded up welders glove or similar piece of leather  works to
  and 71 GA4  383 magnum  SE
