Distributor rotor turns wrong way?
Started by WH23G3G, March 29, 2015, 11:18:28 AM
WH23G3G
I was checking valve clearance on this 65 valiant 170 and when turning the engine by the fan I noticed the rotor was going counterclockwise. Which is out of sequence of the firing order. What does that mean or is this correct for a 170 slant six?
all 6 cyl firing order is 1-5-3-6-2-4....rotor should rotate clockwise....are you sure you were turning the fan the correct way?
bump the starter and see which way the rotor rotates
70 sublime
Do some of the mopar marine motor stuff turn the opposite direction ?
yes, on V8's.....I never saw a slant 6 marine motor when I was working in the marine trade
