BB Rocker Shaft Spacers
Started by Charger_Dart, March 18, 2015, 12:54:14 PM
Charger_Dart
Need a little help with replacing the rocker shaft spacers on my 440. At one time my engine had Crane adjustable rockers on it, but now has the MP stamped steel rocker assemblies. During the swap the aluminum spacers were reused and guess what !?!? They don't mix. The steel rockers ate into the aluminum spacers.
I have searched Ebay and the net trying to locate anyone who might be selling replacement spacers and can't find anything. I only found rocker arm shims MP# 3690896. Can somebody please help me locate a complete set of these spacers (in steel) so I can get my Charger going again?
Thanks!!
68 Charger R/T & 68 Dart GT Convertible
fy469rtse
i used i think from hughes engines , they have a variaty of different thickness's
i still had to mill some for the clearance's but this made it a lot easier,
440 source from memory had some as well ,
just about everywhere , just measure mock up first , try thin shim ones it between the different steels, look at there billit hold downs as well and after market thicker wall shafts,
just to make sure that thats not a result of binding when shafts are snugged down  :2thumbs:
Charger_Dart
Thanks for the tip!  :2thumbs: I checked Hughes and they do have many different thicknesses to choose from. Since I am running stock stuff now, I wonder how thick the stock spacers should be.
BSB67
11.68 @ 120.2 mph
Charger_Dart
Quote from: BSB67 on March 18, 2015, 06:05:01 PM
0.20"
Thanks, just what I needed. Unfortunately Hughes does not have that size, but will keep searching.....
70-500-SE-EXPORT
just get a used set. 440source.com also sells used parts. Call them and ask if they will sell a set. They are not listed on the site but im sure they have them.
68 Charger original SS1 paint with matching # 383hp
Charger_Dart
Quote from: 70-500-SE-EXPORT on March 19, 2015, 11:09:32 AM
I gave them a call but they ran out a few months ago and don't have any. I am hopeful a post to auto recycler's might turn something up.  :shruggy:
ACUDANUT
Yea, those won't work with a flat tappet cam/hydraulic lifters.  Let me see what I can dig up.  I know a have a couple dozen of them.
Charger_Dart
Quote from: ACUDANUT on March 19, 2015, 12:40:56 PM
:2thumbs:
ACUDANUT
Just please remind me. I have alot on my plate right now.  But, I promise to get you these. Just pay for shipping. Can't be more than 5 bucks, right.?
heyoldguy
If ACUDANUT can't fix you up I've got plenty and know right where they are.
ACUDANUT
Well, there you go.  :cheers:
It might take me a week to find these.
Charger_Dart
Quote from: heyoldguy on March 19, 2015, 03:01:59 PM
I wanted to send out a big Thank You to HeyOldGuy for helping me out with a set of these spacers.  :notworthy:
Hope I can return the favor one day.
