Bad vibrations
Started by jww426, March 16, 2015, 07:33:06 PM
jww426
Hello all!
I just put new BFG tires on my 68RT thinking they were the cause of my front end vibration over 50 mph.
Well they weren't.
Please help!
Any ideas?
thanks much
John
JWWIV
RallyeMike
Loose spindle nut or bad bearing?
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
twodko
The first draft of a Beach Boys tune?
Sorry, Couldn't resist.  :smilielol:
fy469rtse
you got me too Tom , was just about to start singing along  :lol:
no seriuosly now , start with the basics , search on here as well , this has been covered for idea's as well ,
take it for a drive , put it nuturel, let it roll , identify if in the tyres wheels bearings or drive line
JR
How old are the lower control arm bushings? Those seem to cause vibration that gets worse as speed increases. Does the vibration change any going around corners?
Sublime/Sixpack
It's possible that your front rims may be a problem. Have you had them checked for lateral and radial run-out?
PlainfieldCharger
How about rusty spots on your drums or rotors? If the car was sitting a while?
jww426
Ill check everything.
How to you test for wheel run out?
thanks!
John
JWWIV
PlainfieldCharger
a magnetic dial indicator will work.
Sublime/Sixpack
Quote from: jww426 on March 23, 2015, 04:35:27 PM
thanks!
John
I've used my dial indicator in the past, but recently found a Tire Shop nearby that has a Hunter Road Force Variance tire balance machine. They can check the rims for run-out and if they're within specs. I have them go ahead and balance the tires. If not, I find a better rim.
It's worked out quite well for me.
