Fuel tank Mods?
Started by Wicked72, March 04, 2015, 08:21:19 PM
Wicked72
I want to use my factory fuel tank. But in the past ive had air get sucked up and stall the motor from driving wild. I will probably use an electric fuel pump either now or when i build the final motor so i was thinking of welding on one of those fuel tank bungs with the AN fittings. But i feel like baffles inside the tank would be a good idea as well. Any ideas or thoughts welcome! thanks
Bob
Air? That would indicate a cracked rubber line. I suppose you dropped the tank and inspected all the lines. I believe you have the evaporator filter above the tank with 4 vent lines into the tank. The fuel filter could be picking up debris also.
Just throwing some things out there that you may have already checked.
Cooter
Just make sure you don't do like a buddy did and weld bung at the front of tank....
course, Holley pumps aren't "intended" for "street" use, but I've run twin Holley Blues for 15 years on the street.
Wicked72
Im saying with exp ive had. my car is an empty shell. Ive seen people use a hole saw and just cut a few holes and weld in a sump so it would act as a baffle.
  My car had a 1/2" bung welded to the very bottom of the tank when I bought it. It had been a drag race only car for about 8 years. After removing the tank and steam cleaning I had the tank shop remove and weld a patch. With all good lines and hose I've never had any fuel delivery issues in many years. I used the car's original (Small block.) fuel as a return line and ran a new line to the pump then to the vapor separator. Adding the correct fuel sender/pickup completed a factory type big block fuel system for not too much cost.
  I did have hot restart delay until I blocked the heat passages to my aluminum intake.
BSB67
Quote from: Wicked72 on March 04, 2015, 08:21:19 PM
Very hard to believe.
11.68 @ 120.2 mph
Wicked72
Quote from: John_Kunkel on March 06, 2015, 03:36:27 PM
Sounds like a job for Hydra Mat
https://www.youtube.com/watch?v=yfE1v65fNZI
this looks great! ill be looking into it for sure. I had an electric fuel bump on my first charger that ran a stock 383 and it worked great. I would like to run something a bit better that will grow with the future mods (built + boost, carburetor). I assume in that case ill need a proper regulator and pump controller? or can a mech pump work well?
Wicked72
hydramat is big bucks! but it seems to be worth it. i think ill give a sump a try first and see if will fit my asshole driving style  :2thumbs:
charger1972
Quote from: Wicked72 on March 07, 2015, 01:21:02 PM
I welded in a sump . Most external h/p electric pumps have to be gravity feed or you risk burning it up . So my pump is mounted lower than I would like . But it functions great and can drive like an asshole whenever I want .
Wicked72
Quote from: charger1972 on March 07, 2015, 05:21:17 PM
:smilielol:
