1974 Dart front brake parts...will they fit the front of "B" body?
Started by A383Wing, February 26, 2015, 10:55:50 PM
I got a chance to pick up a 74 Dart, 4-door, 318, auto, AC (add on I think)
Is the wheel bolt pattern large bolt pattern? Will the front disc brakes and spindles fit on a 68 front end in place of the drum brakes?
If car has add-on AC, thinking of putting it on the Daytona....
Kern Dog
If that Dart has the original disc brakes, then yes.
The spindle and lower ball joints fit the taper of the Chargers Upper ball joints and outer tie rods, so you can take the whole assembly and install it in the Charger. The Dart used front hung calipers though, this will interfere with the sway bar mounting. The trick is to swap the spindles side to side and properly route the brake hose to avoid contact with anything. Make sure the caliper bleeder screws point UP.
djcarguy
     think starting 73 if ya buy the v8 -A-Body you got big pattern disc an rear axle. my 73 Dart 2dr 318 has big disc,an my 75 dart slant 6- 4spd has big pattern disc.  small drums still on my 74 dart /6 an 75 valient /6 4door..
  how is some of nose an sheet metal on that dart ya may get,could use fenders an trunk,tail parts???? ???  will sent ya a PM later.  not sure bout swap of AC from A__TA B body..seems hoses shorter an small block mount brackets very different??
  later have ya had ya Daytona out latttly?  DJ --dart  junky    :popcrn: :2thumbs:
Kern Dog
"  how is some of nose an sheet metal on that dart ya may get,could use fenders an trunk,tail parts?   will sent ya a PM later.  not sure bout swap of AC from A__TA B body..seems hoses shorter an small block mount brackets very different??
  later have ya had ya Daytona out latttly?  DJ --dart  junky"
What ???? Posting while drunk, maybe??
Give DJ a break.  Not everyone is computer literate or just literate in general.   At least you can make out what he's saying.
the 74 Dart I was looking at is not worth the price he wants....so it can sit there and rot even more
Daytona R/T SE
Quote from: JB400 on March 01, 2015, 12:30:28 AM
True,
But...
He should at least take his boots off if he's going to insist on typing with his feet. :Twocents:
djcarguy
Quote from: djcarguy on February 28, 2015, 06:58:41 AM
     WAS 5 AM,,GET ALIFE??? NO DRINKING,JUST SENDING A QUICK MESSAGE ABOUT  BUYING PARTS BRYON MAY NOT NEED.THANKS  BYE DJ
