70 RT Door Scoops
Started by eda4031, January 05, 2015, 11:05:07 PM
eda4031
Anyone know if reproduction scoops, preferably; double sided tape mount, are available?  Thanks
no...the edges of the scoop is too thin for tape to hold it to the door...plus the scoop is too heavy for tape
eda4031
Thanks for your help. Are there reproduction stud mounted units available?
bill440rt
I believe the repro units are stud mounted. If not, it should be fairly simple to bond studs to the backsides of them.
BTW, only two of the holes used studs. The other were metal push clips.
ACUDANUT
I would not drill into the doors and ruin a pair of nice doors. :Twocents:
eda4031
Thanks for the info. From what vendor are reproduction scoops available.  Haven't seen anything from Year One, Classic Industries, etc..
Year One was the last vendor that I saw have them, but that was a while ago
superbirdtom
Quote from: eda4031 on January 05, 2015, 11:05:07 PM
If you want to cut off the studs and use double back tape only use 3m white colored double side tape,# 06381.  This tape is what is used close to factory on their side door moldings. This is all we use at our body shop as the black or grey just dosent hold up. before you use it  and if theirs no way you can avoid the sides being seen just rattle can the sides of the roll black or even body color.
Make sure car is very clean use wax and grease on car and then wipe scoop surface with virgin lacquer thinner- acetone or MEK.  and that the door and scoop surfaces mate exactly.    This white 3m tape is super strong and I would not worry about them ever falling off. If you stik them in the wrong place you wont be able to pull them off.   So make sure you have them exactly in the right spot and press very firmly.    Ive attached hood scoops- spoilers etc without ever a bonding issue.
polywideblock
don't think it will make any difference one way or the other the repo  scoops appear to be MIA    :yesnod:   can't find them anywhere    :scratchchin:
      think there's a buck to be made here  :Twocents:
  and 71 GA4  383 magnum  SE
superbirdtom
hmmmm.  that goes with a lot of other parts that are not used much. like the blasted full quarters on 70 super bee I am looking for :'(         mabe buy the skins an graft on sail panels an drip rail from a set of 69 rr full quarters . but I think the 70 coronet quarters are a complete different one off stamping no substitute  anywhere from panel skin up to lead line or above tail light etc.
eda4031
Thanks for the tip about the 3M tape. I see another member has had the same luck I've had trying to find them on line.
