512 Parts List
Started by comet_666, December 30, 2014, 02:38:01 PM
comet_666
Long list for my 512 build..not sure I am missing anything other than carb/ignition and such. In no way is this final but something I was working on during slow work day.
Please critique! I have never done this before!
512 Stroker Kit -$1999
http://store.440source.com/Stroker-Kits/products/3/
Stealth Aluminum Cylinder Head - COMPLETE
Item Number: 200-1055 - $1000
Comp Cam Xtreme Energy Hi-Lift .564" Item Number: 145-1229 $150
http://store.440source.com/Comp-Cam-Xtreme-Energy-Hi-Lift-564/productinfo/145-1229/
COMP Cams 529-16 - Comp Cams Viton Metal Body Valve Stem Seals $38
http://www.jegs.com/i/COMP-Cams/249/529-16/10002/-1
Hughes Engines PREMIUM BB 1.5 ROCKER ARM KIT W/ SHAFTS HUG 15103 $600
http://www.hughesengines.com/Index/products.php?browse=category&level0=RC0gQmlnIEJsb2NrIChMb3cgRGVjayk=&level1=Um9ja2VyIEFybXMgJiBBY2Nlc3Nvcmllcw==&searchmode=partnumber&page=1&partid=26774
Johnson Hydraulic Lifters SUM-HT2011 - $70
http://www.summitracing.com/parts/sum-ht2011
Comp Cams "Super Lock" Steel Retainers - $60
http://store.440source.com/Comp-Cams-Super-Lock-Steel-Retainers-Set-of-16/productinfo/145-1003/
Comp Cams "Super Lock" 11/32" 10deg. Valve Locks Item Number: 145-1002 $30
http://store.440source.com/Comp-Cams-Super-Lock-11_32-10deg-Valve-Locks/productinfo/145-1002/
Stealth Cylinder Head Valve Spring Cups - Item Number: 200-1066 $25
http://store.440source.com/Stealth-Cylinder-Head-Valve-Spring-Cups-Set-of-16/productinfo/200-1066/
Comp Cams Dual Valve Springs for Hyd Cams over .510" lift
Item Number: 145-1013 - $130
http://store.440source.com/Comp-Cams-Dual-Valve-Springs-for-Hyd-Cams-over-510-lift/productinfo/145-1013/
Holley Street Dominator Intake Manifolds 300-14 - $230
http://www.summitracing.com/parts/hly-300-14/reviews/
Sheet Metal Valley Pan - RB Engine - Single Plane - $30
http://store.440source.com/Sheet-Metal-Valley-Pan-RB-Engine-Single-Plane/productinfo/127-1009/
Intake "Facing" gaskets - Set of 4  - $15
Intake Valley Pan Gasket - $20
http://store.440source.com/Intake-Valley-Pan-Gasket-RB-New/productinfo/112-1001/
Rollmaster BB Mopar timing set - 3 Bolt $140
http://www.buyracingparts.com/timing-sets/rollmaster-bb-mopar-timing-set---3-bolt.html
ARP Bolt Kit - 3 Bolt Camshaft Item Number: 129-1007 - $10
http://store.440source.com/ARP-Bolt-Kit-3-Bolt-Camshaft/productinfo/129-1007/
Complete Engine Gasket Kit - $60
http://store.440source.com/Complete-Engine-Gasket-Kit/productinfo/112-1000/
Mancini Racing Aluminum Water Pump - Item #: MRE-86900 $95
http://www.manciniracing.com/mabhealwapu1.html
Mancini Racing Aluminum Hi-Vol. Water Pump item #: MRE86800 - $80
http://www.manciniracing.com/mabalhiwapu.html
Fel-Pro Water Pump Gasket - item #: FEL11730 - $3
http://www.manciniracing.com/bwapuga.html
Mancini Racing Water Pump Housing to Block Gaskets - item #: MRE-136 $5
http://www.manciniracing.com/bwapuhotoblg.html
Billet Aluminum Water Neck - $30
http://store.440source.com/Billet-Aluminum-Water-Neck-New/productinfo/114-1004/
Bolt Kit - Water Neck or Fuel Pump Block-off Plate - $5
http://store.440source.com/Bolt-Kit-Water-Neck-or-Fuel-Pump-Block-off-Plate-2/productinfo/109-1519/
Thermostat 180 deg. - $10
http://store.440source.com/Thermostat-180-deg/productinfo/138-1009/
Fluid damper - SFI Certified - Chrome - $150
http://store.440source.com/Fluid-damper-SFI-Certified-Chrome-New/productinfo/200-1023/
SFI APPROVED Solid Flexplate - 6 bolt - Neutral balance Item Number: 200-1084 $50
http://store.440source.com/SFI-APPROVED-Solid-Flexplate-6-bolt-Neutral-balance/productinfo/200-1084/
ARP Bolt Kit - 6 bolt Flexplate to Crank Item Number: 129-1003 $15
http://store.440source.com/ARP-Bolt-Kit-6-bolt-Flexplate-to-Crank/productinfo/129-1003/
Bolt/washer - Damper to Crankshaft - $10
http://store.440source.com/Bolt_washer-Damper-to-Crankshaft-Short-Grade-8/productinfo/109-1503/
Timing tab - Plain Steel  - Item Number: 121-1014 $6
http://store.440source.com/Timing-tab-Plain-Steel-New/productinfo/121-1014/
Timing cover - Plain Steel - Item Number: 121-1012 $25
http://store.440source.com/Timing-cover-Plain-Steel-New/productinfo/121-1012/
Timing Cover Bolt Kit  Item Number: 109-1520 $12
http://store.440source.com/Timing-Cover-Bolt-Kit/productinfo/109-1520/
Timing Tape - Item Number: 200-1121 $8
http://store.440source.com/Timing-Tape/productinfo/200-1121/
Milodon Freeze Plug Kits 34041 - $20
http://www.summitracing.com/parts/mil-34041/overview/make/chrysler
Melling M-63HV High Volume Oil Pump - $80
http://store.440source.com/Melling-M-63HV-High-Volume-Oil-Pump-New/productinfo/M63HV/
Oil Pump Gasket - $8
http://store.440source.com/Oil-Pump-Gasket/productinfo/144-1002/
Valve Covers - Fabricated Aluminum - $170
http://store.440source.com/Valve-Covers-Fabricated-Aluminum-pair-USA-MADE/productinfo/200-1052/
ARP Stud Kit (long) - Valve Covers - $40
http://store.440source.com/ARP-Stud-Kit-long-Valve-Covers/productinfo/129-1030/
CNC Aluminum Oil Cap - $15
http://store.440source.com/CNC-Aluminum-Oil-Cap/productinfo/121-1051/
Filter Style Breather - $15
http://store.440source.com/Filter-Style-Breather/productinfo/121-1059/
Kern Dog
Just curious:
Why 512 ? Is it because the price is the same as it is with less cubes? I ask because I see so many people building long stroke engines and then just cruise them around. A stock stroke 440 can really scram and get 2-3 more mpgs on long trips. Running more cubes and not using the extra power they provide is like carrying 500 pounds of useless weight in your trunk. It only costs you money. I see that you mention the 440 Source heads. These heads are great on 383s and 440s but are a bottleneck on a 500 inch engine unless they have some port work done. They have potential but will not feed 512 inches. My 493 really woke up once I had the Edelbrocks ported. I can only imagine how an engine with almost 20 more inches would be.
Your cam will require a high stall converter. Some of them really suck at freeway driving especially if the stall rating is higher than your cruise rpm.  I didn't read what your compression ratio will be, but I do know that 440Source offers a dished piston option. They calc to around 9.28 to 1 with a .018 deck clearance. Deck the block that .018 and the compression still is below 10.0 to 1. This is great and will be compatible with 91 or 93 octane fuel.
I am currently running a 493, 10.07 to 1 with a Lunati flat tappet solid lifter 261* I 271* E @ .050, .556/.578 lift. The cam runs strong but is a bit soft under 3000 rpms. I'm switching to the MP 284/528 cam to improve street manners. I want better off idle performance than the big Lunati gives.
Good luck, Greg
comet_666
I am going to clean the heads up a bit. I am thinking 512 because my boss did one for his Dart and without too much hassle it went right together and had good numbers. I should mention it will ow be a 727/3.91 car as well. once we make sure block is good to go then we can get the block work done and order the kit... you thinking dished pistons?
Kern Dog
I have flat tops with valve reliefs in mine, .012 below deck. I used to have approx 10.9 to 1 CR with the .039 head gasket. I had a quench distance of .052 which is outside the target of .035 to .045. If you had a dished piston sitting at zero deck, the .039 head gasket puts you exactly in the sweet spot for quench while the dish of the piston reduces your compression ratio to a safe level for the street.
I dealt with detonation in mine, so I am sorta gun shy about running over 10.5 on the street. There are guys that tell you that you can run 11.5 to one on pump gas if you have a big cam, but to me that just makes the engine less streetable. The big cam gives away low end torque in exchange for more high RPM power. I'm not interested in the poor cruising performance that comes with a big cam and a high stall converter. During all of my experiences over the past 2-3 years, I learned that a moderate compression ratio allows you to run more spark advance. The HP gains of the proper ignition timing outweighed any loss I had from lowering my compression from 10.9 to 1 down to 10.07 to 1.
The other reason I'm in favor of dished pistons is that it buys you a bit of tolerance if you are out on a road trip. We are always at the mercy of what fuel is available and I've been near empty and had to run 87 octane just to get to the next station down the road. I hated the feeling of being on the edge of detonation all the time. It really took the fun out of driving the car. I finally installed thicker head gaskets because I wasn't interested in pulling the engine out for a piston swap. If there is an occasion to pull the engine in the future, I certainly will change to some sort of dished piston like we have mentioned here.
Kern Dog
I do not pretend to know all the answers on the subject. I just know what works for me. My high compression ratio meant limiting my ignition timing to 30 or 31 degrees total, running 91 octane at a minimum and only flooring it in cool weather. Once the weather went above 70 degrees, the car would knock if I went past 3/4 throttle. I did some testing with race gas. A 50/50 mix of 91 and 104 helped but it still knocked a bit. A 50/50 mix of 91 and 110 almost eliminated it. Straight 110 allowed me to move the timing to 34 without any knock and the car was crazy fast! The 110 was $ 60 for 5 gallon pails though. I just wanted the convenience of driving the car how I wanted without any "crutches" like octane boosters, backing off the timing, water injection, etc.
I kne that the simple truth was that I either needed MORE octane or LESS compression. Many guys were confused as to why my engine knocked with only 10.9 CR , saying that they run well over 11.5 and theirs runs fine. I'm limited to 91 octane here in CA, plus we run 10% Ethanol in the gas. Most guys online thought a bigger cam with a later intake closing point would help. I preferred the idea of using a thicker head gasket to lower the CR. Most guys thought it was a bad idea and that my knocking would get worse due to the loss of quench. Since I was feeling overwhelmed with all the one sided responses, I took the advice of a guy on FABO and ordered a bigger cam that he suggested. It turned out that while that cam was bigger, my detonation got worse. I finally did what I wanted and called Cometic for a pair of the .075 gaskets. While the heads were off I had them ported. After reassembly, the car did not knock, made more power and I did my own private victory dance.
cdr
fy469rtse
And I would measure main caps versus crank, 440 source can be a little loose on there clearances,
The ones I have found have more like race clearances,
With this build , attention to detail is the key to a healthy engine , through.y clean everything ,
Post when your ready and start a list of what to do with bare block
I'm sure everyone will contribute
1. Chase all threads with bottom tap to ensure good torquing of head bolts etc
This can be done before or after engine shop does its work , I prefer to do it before hot tank on block
fy469rtse
Ditch the timing chain off your list to 440 source,
Get a roll master one ,
Look up the thread on hear for checking and blueprinting oil pumps , you wouldn't believe how bad they can out of the box new
fy469rtse
Have a look for thick wall bananna groove rocker shafts, also billit hold downs will stop shafts from ovaling under torque from hold down bolts
fy469rtse
Ditch the water pump,
Waste of money,
There's a thread on hear with member tested all , factory ones were the best , hemi style 7 blade with anti cavitation plate , doesn't matter if not alloy,  :2thumbs:
fy469rtse
Also water neck , look for billit one that's o ringed ,
A lot less chance of it seeping , factory ones or similar known to seep
fy469rtse
Oil pump gasket comes with the gasket kit and with the new pump,
Delete that off your list
fy469rtse
Double check your camshaft, a lot of those extreme energy cams single bolt , ? And you 3 bolt billit cam gear
Personally....I'm not a fan of fluid dampners.
The elastomer style would be my first choice.  :yesnod:
comet_666
fy469rtse
Good , best advice is to keep reading, be informed about what your doing ,
The more you understand the better the choices will be,
I'm trying the fluid damper for the first time , so far there's no problems
But I chose this for other reasons , I'm running a milodon gear drive,
And this set the pulleys out further, fluid damper helped line these up
Compression ratio will be critical with head choice,
Detonation, so re read I think Kerndogs post , and a lot of reading on known threads on here,
I'm running the victors with 11.25 comp ratio , with no detonation,
Challenger 340 doing a similar thread on his current build , look for that 512 also  same heads
fy469rtse
Ditch the freeze plug kit, get milodon
There's cheap and the there's poor quality, cheap has less wall thickness, shoulders not as deep, ? Just freeze plugs,
But the last issues you want to have is coolant leaks that result in engine being pulled to fix ,
comet_666
Ok, here is another parts list from my builder. Thoughts?
Eagle Comp rotating assembly 21203
Edelbrock rpm Heads
Performance cam brgs.
Edelbrock Intake rpm 7193
Canton Pan 15-950
Canton Pick up 15-951
ARP Main Cap Studs 140-5402
ARP Head Bolts 145-3706
Brass soft Plugs
Felpro Head gasket 1009
Mr Gasket Performance pan gasket
Hyd Roller Cam 723445-10
Comp Pro Magnum Lifter Hyd.Roller 8921-16
ARP SS Intake Bolts
Harland Sharp Roller Rocker arms S70015K
Timing Chain set Roller thrust brg.
Oil pump 63HP Melling Select
Oil Pump Drive Brass gear for roller gear p3690875
Manley3/8 x.08 Pushrods
Milodon Water Pump 16260
Carb QF 780VS
MSD Ready to run Distributor 8387
MSD Wires
MSD Coil
fy469rtse
Ooh l like that list, ? Difference in $ , bet its a big jump huh
Is that a HV oil pump , ditch that and go stock , pump will still need to be detailed , blueprinted
You will not need that HV pump extra drag on bronze gear , I learnt the hard way,
Still go stock replacement water pump, no benefit on so called aftermarket ones
Firecore ignition set up will save you $
That hydraulic cam will cost you more $ in block machining work , I would look for another cam shaft if needed to run bronze gear , wear point read soft ,
Lifter bores will need to be machined and bushed for oil control,
comet_666
And yet another, thanks for the help on this fy469rtse, your input is invaluable!!
Victor Edelbrock 440 Cylinder Heads (ported) with Hughes 1.5 Rockers and stainless steel valves with dual springs and damper
Edelbrock Intake Victor 2954
Brass soft Plugs
Internal / External Balance Damper 200-1128
Milodon Balancer Bolt
ARP SS Intake Bolts
Water Pump  MIL16260
Polished Valve Covers SUM440350
Carb QF 780VS
Firecore "RB" Ready To Run Distributor MRED93871
Taylor Spiro-Pro Spark Plug Wire Set TAY74072
FireCore Performance CD R2R Mini Coil MREFC-CDM
MSD Hold clamp and Seperators
ARP Stainless Header Bolts
cdr
better do some research on bb mopars & hydro roller lifters !!!!!  just sayin
Challenger340
Correct me of I am wrong here ?
But,
the Eagle 21203 Kit is a 4.375" Stroke Crank ?
If you are using an aftermarket Race Block, read no further and disregard the following.
If using a "stock" type Block......
Been awhile since we put one of those in a "stock" Block, (we normally default to an aftermarket Block past 4.250" Stroke)
That said,
Is your builder familiar with BB Mopar Strokers ?... and has a plan ?
because,
anytime I put a 4.375" Crank in a stock Block.... with an INTERNAL Oil Pickup.... I have to set the Block up in the Mill and move the pickup Hole over closer to the pan rail, re-thread, then re-Port the Pickup Oil gallery back in the line with the pickup ?
No easy task, gets "thin" over there  ?
Just say'in.... and NOT my place to go schooling anybody, but is he aware the 4.375" Stroke Crank will have some interference "issues" with the Oil Pickup Boss on stock type Blocks ? Canton Internal Pickup ?
Just make sure he has priced in the extra machining operations Labor to accomplish the internal pickup mod with the 4.375" crank ?
or,
maybe he has done this before and has his own way of doing things ?
No offense intended, just trying to help... I certainly don't know everything !
Only wimps wear Bowties !
comet_666
I will get more info from him and update
He did mention canton pickup though..
Thanks!!!!!!!!
Kern Dog
Good points made here.
If the OP took the time to post, he should pay attention to the responses. DO research. Ask more questions. The trend to build the biggest engine you can is tempting but what is the point of the build? Is this just to be able to brag about the engine size? Do you intend to pull a house off its foundation? Plan to pull a 10 car trailer? Run a 9 second 1/4 mile?
The further you deviate from stock the more money you will spend. Why? Are you going to actually see the benefits of the efforts? You can make great power without resorting to extra machine work and custom parts. Even the 4.15 stroke takes you right near 500 inches with only small notches at the bottoms of the cylinders for rod clearance. My stock oil pump pickup clears without resorting to any crazy mods.
comet_666
Believe me I am paying attention to the responses here and they are all very much appreciated!
I am just trying to nail down where I want to go with this so I am all over the board a bit  :brickwall:
When I narrow my lists of builds down I will post and see what you guys have to say!
