new a/c compressor oil?
Started by Stegs, December 23, 2014, 07:22:14 AM
Stegs
does anybody know what kind of oil is need for a new a/c compressor? Its a rock auto compressor - reman from four seasons.....
and how much
I read thru the manual, i couldnt find where it said type, but i think it said 6-8 ounces
any help would be great to help me finish this project up
no where on rock auto or in the directions does it say type of oil or amount
fyi, i will not be using the air conditioner at all, I just need the oil to keep the compressor from seizing up like my last one did
PlainfieldCharger
I think the oil used depends on the Freon used.  :scratchchin:
Pete in NH
The factory fill for a new compressor and empty system is 10 to 11 oz. of oil. Since some of that oil gets carried around the system you should find about 8 oz. left in the compressor. Since you will not be using the A/C system ,I would fill the new compressor with 8 oz. of oil. The oil type does depend on what type of refrigerant is used. The original oil for R-12 is 525 wax free mineral oil for A/C systems. I suggested in your other A/C thread you use an ester based oil like BVA 100 which would be compatible with either R-12 or the newer R-134A should you want to get the A/C working again at some point.
Stegs
Quote from: Pete in NH on December 23, 2014, 09:15:13 AM
8 ounces of bva 100 is what i will get then..
and then check the level accordingly
