'71 Hits the Paint Booth
Started by 71charger_fan, October 25, 2014, 10:06:06 AM
71charger_fan
Doors going on, valance and spoiler on. Don't remember the routing for the hood release cable though.
71charger_fan
Coming together. I had a hard time choosing between chrome and body color mirrors.
71charger_fan
Today was glass day.
hemi-hampton
NHCharger
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone
2014 RAM 2500HD Diesel
ACUDANUT
 Now it needs white R/T stripes.  :cheers: :cheers:
71charger_fan
When you've just finished installing an A/C compressor this is not the optimal outcome when you go to hook up the line. Fortunately, I had a spare compressor.
71charger_fan
I ran and hooked up the A/C lines and the heater hoses. There's no decent heater hose diagram in the FSM for Charger/Coronet/Satellite with big block and A/C. So, I don't know if it's right or not. I also reinstalled the brake hardlines/distribution valve/master cylinder. I was working alone so had to improvise to hold up the MC while I went under the dash to install the washers and nuts.
71charger_fan
I put the front bumper/grill assembly back together today.
71charger_fan
I also swapped out the cruddy calipers for a freshly painted pair.
71charger_fan
Today, got the brakes bled, front bumper/grill on, dome light wire fished through the A-pillar and a few other random things that needed to be done.
71charger_fan
Getting very close.
71charger_fan
Now to get the hood adjusted, install the steering wheel, hook up the battery, and hope for the best.
ACUDANUT
No R/T Stripes ?  You added a front R/T spoiler...Very nice either way. Cheers.
AKcharger
It's gonna move under it's own power soon!!!
71charger_fan
Column is in and wheel is on. Now to figure out why the horn won't shut up. That's a job for Monday.
NHCharger
Is that a Flaming river steering column?
71charger_fan
Flaming River column, adapter, and wheel. The only real problem is that the Flaming River column is smaller diameter than the original column and the floor mount doesn't capture it correctly. I bought the Flaming River E-body floor mount. We had to enlarge a couple of the holes, but it worked fine.
71charger_fan
What a relief to pull the headlight switch and have the lights come on and the headlight doors open.
71charger_fan
Of course, now I have another big thing to store.
71charger_fan
What is this? Shop note on the tape just said "left frame rail." Where on the frame rail? Pointing up? Down? Forward? Back?
70 sublime
Does it go below the brake booster area on the frame rail to hold the cables going to the starter ?
71charger_fan
That makes sense. Looks like I no longer need it. With the Schumacher headers and the mini starter, the starter wire now goes down the side of the block.
71charger_fan
Found these two things in one of my containers of extra clips, bolts, screws, etc. Anyone recognize them? Where they attach? What they're for?
