'71 Hits the Paint Booth
Started by 71charger_fan, October 25, 2014, 10:06:06 AM
ACUDANUT
Quote from: 71charger_fan on January 08, 2021, 09:08:01 PM
The rear of the unibody should soon be in epoxy primer.
Looking Great !!
71charger_fan
Taking it down to bare metal was absolutely the right call. The door jamb was peeling down to the bare metal.
71charger_fan
Quote from: CFMopar on January 11, 2021, 03:08:17 PM
Hey if you don't mind asking your shop next time you're there.
Do they know of a source for Cowels and front frame rails for 71?
I got my frame rail from auto rust technicians. Now, their website refers you to Classic Industries. I couldn't find their products on Classic Industries' website.
You may be able to use a Challenger/Cuda cowl. They look pretty much the same. If nothing else, you might be able to use one for patches for yours.
71charger_fan
Two coats of epoxy went on yesterday.
71charger_fan
Still a long way to go.
NHCharger
Wow, nice. Glad you finally found a reputable shop.
you need to hustle if you plan on making Carlisle this year.
Are you planning on going?
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone
2014 RAM 2500HD Diesel
71charger_fan
I've pre-registered. I hope to bring the Charger. If it's not ready, I might just switch the registration to the '55 Plymouth (again) or to my '15 Scat Pack and ride up there in air conditioning. The front fenders need a few patches, then it's into body work then paint. I'll do the interior at the house myself.
It's a sad commentary on body shops that it's so hard to find someone who cares about the product he puts out.
NHCharger
Quote from: 71charger_fan on January 17, 2021, 12:36:41 PM
Yup. That's why I ended up doing everything myself. The guy that did my 71 Charger did do a good job but he was rather quirky and difficult to deal with at times.
Probably 20+ years of paint fumes has done a number on him.  ;)
I'm going to register for Carlisle this week.
hemi-hampton
Quote from: NHCharger on January 17, 2021, 03:32:54 PM
So, that's what's wrong with me :scratchchin:
NHCharger
Quote from: hemi-hampton on January 17, 2021, 05:12:49 PM
That's ok, we still luv ya.
All kidding aside, I know two local bodyshop guys that spent the majority of their lives in the trade. One NEVER wore a mask except for final paint, the other would actually smoke a cigarette while sanding and priming. Both are now suffering a slow miserable death.  I'll wear a full respirator even when I'm just sanding filler.
71charger_fan
Now the epoxy, seam sealer, etc can cure while a Mustang gets its paint.
71charger_fan
With the doors properly aligned to the quarters, the car now needs fiddling to align the fenders to the doors.
  ;)  me too  :scratchchin:
Quote from: NHCharger on January 19, 2021, 08:40:55 PM
i use to also when blocking filler, in the end i become over sensitised all the fumes of everything in a body / paint shop ,  i would  even wear a proper charcoal mask when even just mixing filler & troweling it  on  :P.  even just mixing paint / primers & cleaning guns. was better when we changed to waterbase 20 yeas ago , but still used 2k MS HS solids & clear coats primers ,
use to wear all the correct safety gear masks suits gloves full face airs feds &  still affected me , in the end even just the smell of cutting / polishing compound would affect me  :icon_smile_blackeye:  :yesnod: sorry for the mini hijack , just take no chances guys
Quote from: 71charger_fan on March 02, 2021, 01:02:19 PM
:coolgleamA: looks good !   :popcrn:
AKcharger
It's true! that's why Leon hastled me during my bodywork/paint!   :hah:
So glad that it finally looks like a car again!!
ACUDANUT
 I love it. Although some here hate 3rd gen Chargers. FT. I own 3. :nana:
hemi-hampton
Do all the body lines line up. LEON.
71charger_fan
Once the driver fender gets dialed in all the body lines will be lined up.
71charger_fan
After some persuasion, the front fenders are aligned to the doors and the gaps are set.
hemi-hampton
was that persuasion with a hammer?
71charger_fan
71charger_fan
A hit on the driver side fender dating back before I owned the car is complicating getting the hood to fender gaps right.
hemi-hampton
Yeah, That don't look to good. Looks like both the Fender & Hood is part of the Problem unfortunately. :scratchchin:  Good Luck :scratchchin:
71charger_fan
The hood's a '74. But, the original hood rubbed at the front driver side corner since I bought the car in '86. If I have to accept a less-than-ideal hood to fender gap, I can live with it.
hemi-hampton
You shouldn't have to live with that, it can be made straight, i've done many before, may not be easy though, sometimes you gotta cut & weld ect., ect., I had one bowed out so bad (gap like over 1 inch wide) I had to weld a long steel plate along top of fender edge & pull on frame machine. Good Luck
71charger_fan
I was thinking a couple of relief cuts on the inside of the forward third of the driver fender might do the trick. I'm sure my body guy will get it. He's very, very picky. I'll probably drive up there Monday or Tuesday and see how it's going.
